Pro Connect Panasonic Battery - Have I got a problem?
oriteroom
297
110
Hi all
Have I got a problem starting with the Panasonic battery on my Kalkoff Pro Connect or did it just go into hibernation because of the cooler nights?
This morning when I went to get my Pro Connect out, no lights would light up either on the battery or on the handlebar control switch. I put it in the charger and three lights lit up which was the state I left it in 12 days ago after my last ride on it.Taking it off the charger (didn't have time to charge the battery back up) everything was normal again with three lights on the battery/ two on the handlebar and the 'cell test' returned all five lights up. I've seen that the colder weather can affect the batteries and flecc in his excellent guide notes that batteries will go into hibernation after about two weeks if they're half charged. Been out today on the bike (v minor battery use) but it's back on the charger tonight to charge it back up to full. My wife's bike was similarly left for 12 days under identical conditions but she had 5 lights on the battery and her's was normal this morning (again flecc notes an almost fully charged battery will take a lot longer to go into hibernation).
For info/interest the stats for the two batteries are
Mine - 15 months old, 17 charges (approx 1/month), 2830 miles covered, average 170 miles per charge, and for the last 8 charges I've measured the total energy put back which averages 7.8 A/hr. After the first two conditioning charges, I normally run the batteries down to 1/2 lights.
My wife's - 15 months old, 13 charges, 1850 miles covered, average 140 miles/charge, average recharge of 6.5 A/hr (Normally recharge hers with 2/3 lights as her usage is a bit less since she's only 1/2 my weight!!)
As you see we mainly use the power for hills and adverse weather (wind!!)
My main questions are:
1. Did my battery just hibernate after 12 days on 3 lights remaining?
2. If a Panasonic battery does hibernate should you charge it up fully again before use or as soon as possible?
3. Should I complete a charge/complete discharge cycle after a battery has hibernated?
4. What is the perceived wisdom for battery storage in the winter Leave it in the shed on the bike or take it indoors in the warm? Our situation is we tend to have longer resting intervals in the winter (can be 2-3 weeks if the weather's bad) than in the summer when we're out every few days.
Thanks for any replies.
Mike
HarryB
1,317
London
30,848
1) Yes, I think your battery did hibernate Mike, despite the 12 days and 3 LED indication. That's especially likely if it was in the shed since the colder weather we've been experiencing could have dipped the capacity and LED readout later without you being aware of it.
2) You should charge it first, but if you don't fully charge it, no harm will be done but the metering will be inaccurate until you do a full conditioning cycle down to fast flashing LED indication.
3) As (2) above.
4) Cold is better since it slows the continuing chemical reactions in the battery which age it regardless of the hibernation mode.
JamesC
435
Peterborough, UK
Mike
Thanks for the excellent description of the 2 batteries - also congratulations on the way you use the assistance - 150 odd miles per charge is impressive.
It sounds exactly right that your battery went into hibernation - if the charge level is under 50%, it enters hibernation in approximately a fortnight. If it is fully charged, it takes approximately 4 months to "self-discharge" to the 50% level to enable hibernation.
As soon as you woke it up on the charger, the "cell test" still showing 5 lights confirmed that the short time during which the BMS (Battery Management System) had been asleep, had been insufficient for the cells to become significantly unbalanced.
With a balanced "cell test" showing 5 lights, I don't believe there is any need to do a full reconditioning/rebalancing cycle at this stage.
From your description, this situation could arise 3 or 4 times through the winter, so I would be inclined to do one full discharge in the spring to bring it back to full accuracy.
James
oriteroom
297
110
James, Flecc, and HarryB
Thanks for all your helpful comments.
Mike
