Quick BMS question
johnc461165
546
22
WN6
I have searched the site looking for a general BMS cut out voltage for a 36v Li ion. I don't have a problem it's for information only, thanks. John
It depends what the programmer selected - normally between 29v and 31v.
trex
7,703
2,671
you can't. There is no access to this function from outside.
Dudley Arnold
Apr 5, 2015
Why do you want to alter the LVC on a BMS?
Thanks Trex and d8eh for replies. I have a BMS that switches off at about 38volts. When shorted it runs. It is a 10cell unit. Can I access the lvc and adjust? Got images, but cannot work how to get them on......?
LVC works at a cell level rather than global. Is it a 12S BMS? Some 12S BMSs can work with 10 cells if you short the last three pins together. You'll need a 12S connector to with only 10 sense wires connected. Some 12S BMSs use a 13 pin connector and others a 12 pin one.
There was a really cheap 10S BMS on Ebay last week. Would that be a better solution?
