R&M Super charger GX rear pannier rack paint wear issues
mountaindweller
23
12
Just thought i would post an issue that i have had with my new R&M supercharger GX, purchased from new seven month ago, i completed a tour in Europe and found that the rear pannier rack had suffered significant paint wear, caused by my Ortlieb panniers rubbing on the rear support bars.
i have contacted R&M and their reply was .............
thank you very much for the forwarded pictures.
The damage is, as described by you before, most probably caused by the friction of bike bags.
As we are aware that this can happen under certain circumstances, we included a recommendation, in our bike instruction manual, to secure the contact points with tuffcoat foil.
To prevent further damage, we are happy to provide you tuffcoat foil. This would however need to be delivered to a Riese & Müller specialist of your choice, as we only deliver to our contract partners.
We would also like to advise you to contact your local Riese& Müller bike dealership yourself. There they might be able to cover up some of the patches with finish.
It would be nonetheless, most important to again cover the contact points with foil, after any kind of repairs has been done.
I Have contacted my dealer, who thinks the cover paint job is a non starter, and is working on a better solution ? , i explained to R&M that i previously used Tubus racks and that the paint never rubbed off , and pointed out that they should validate their paint as it appears to be inferior to others, as for how the bike will look with this Tuffcoat foil or any other protection !, would not look good as an advertisement for what is a very expensive E-bike which was specially designed for touring , however one must protect the rear rack if considering using panniers. Note photos show identical wear both sides
RobF
4,732
2,311
Some small scuffs on the rack of the Charger in my avatar.
The rest of the paint seems to holding up as well as any other bike I've had.
6,319
mountaindweller
23
12
If you've something rubbing on the paintwork it will wear through, what on Earth do you realistically expect? It's paint, it's not armour plating.
Like i said , i have used Tublus racks for years with no problem, do you own a supercharger ? the paint work is a matt black finish and easily rubbed off , by non metallic parts and even my own dealer has commented on the amount of R&M bikes he has seen that use those pannier racks with worn paint.
Amoto65
807
502
Cheshire
If I had spent that much money on a bike I would have put protection tape on any parts that were obviously going to rub before doing a European tour, especially if it advises to do so in the instruction manual.
mountaindweller
23
12
The photos that i put up are just the main wear , the rack is a mess, like the metallic matt finish is to thin and inferior , sure , maybe i should have taped up the contact points, that would be where the stay clips attach , but its the whole bag that is against the rack , so like i tape the whole rack ! and like i have been touring the planet with Tubus racks and never experienced this before , as for how my dealer views this, he says the paint sucks , cheap for a very expensive bike.
Amoto65
807
502
Cheshire
Actually the contact points would be where the bag was touching the rack and obviously anything that is rubbing against it for a prolonged amount of time is going to cause the paint to rub off.
