Help! Raleigh Velo
Lordhorsegate
Jul 26, 2019
Hi, I have just tried to charge the battery and when you plug it in the charger light goes green and the battery says 20% charged. It has been on charge now for 6 hours and is still only showing 20%
Tim
Andy-Mat
2,214
562
77
Tim
That sounds like that the battery is below the level at which it allowed to accept a charge from a normal charger.
Depending upon the nominal voltage, there is a set limit as to how low the battery's voltage is allowed to go, before charging cannot take place!
A bike shop may be able to "recover" the battery with what is called a "Zer0 volt Charger".
Try one.
regards
Andy
Lordhorsegate
Jul 26, 2019
Try one.
regards
Andy
Lordhorsegate
Jul 26, 2019
Thanks Andy, I have just put the battery back into the bike and the control gear says it's fully charged !
Will give it a try over the weekend and see what happens.
Tim
Andy-Mat
2,214
562
77
Tim
Good for you!
It sounds like it was a false alarm!
regards
Andy
8,230
You need a meter to check the out put voltage, it takes a lot of guessing away.
