Rear derailleur problems
suggy
47
I have a carrera crossfire bike and i find the rear derailleur to be prity useless i have tried all sorts to sort the shifting
out. So i am after buying a new one can anybody recommend a descent shimano model because that is what my shifter is.
any help most appreciated
2,829
The issue is most likely in the cable; rusty or broken strand of wire especially where it is inside a casing, or taking a slightly wrong path (eg round the bottom bracket).
6,697
also check that the mech hanger is not bent as will also cause poor shifting.
Andy-Mat
2,214
564
78
Look on YouTube for the adjustment procedures, once the previous thoughts from others here have been checked out!
In my limited experience, its usually a cable, I forget to lube mine, and then comes rust or dirt!
Or both!
Replace with quality versions and lube well.....
Andy
awol
1,216
374
I have a carrera crossfire bike and i find the rear derailleur to be prity useless i have tried all sorts to sort the shifting out. So i am after buying a new one can anybody recommend a descent shimano model because that is what my shifter is. any help most appreciated
I've just had your same problem and I traced it to the cable snagging slightly on the plastic cable guide under the bottom bracket.
I've used this model for years and it seems ok.
Reactions: Andy-Mat
8,740
Jagwire stainless steel gear cables are cheap replace your old cable.
