Replace 2 wire motor cutout switch with three wire Minshine in-cable device
jokskot
156
47
75
I would like to replace the current two wire (presumably normally open) brake activated switches on my ebike with a Minshine (model MS-BK-1R) in-cable sensor as I'm changing the brake levers to integrated brake and gear shifters.
So far as I can tell, my control box has input for a two wire sensor only.
Can anyone tell me how to do this, please?
I understand that the Minshine senses movement of the inner cable, but how does it achieve this?
16,466
5,785
Inside the sensor box there is a magnet which "grabs" the steel brake wire and moves with it past a hall sensor.
jokskot
156
47
75
Thank to you both for your replies. Is there any way I can use this (Minshine) kind of sensor if the only (obvious) connection is a two wire "make" via the existing in-lever switch?
16,466
it's just not worth the hassle.
I used to keep Y1T4 type cables for this because Bafang sensored brake levers are with Hall (3-pin yellow plug) but since universal 2-pin red plug brake sensors are available, I don't keep them any more.
To use the inline HWBS, you have to run the wires directly to the controller - it's a mess unless you already have internal cable routing.
jokskot
156
47
75
Thanks again for your response Woosh.
I don't have internal wiring, but don't see why it would be any messier to run a wire from the in-cable sensor to the control unit than is currently the case where wires are run from the brake lever switches to the controller...and wouldn't the device that you included in you first reply have to be connected back to the controller?
Could/can a connection or input be made using the Hall effect in-cable sensor where the controller does not have any obvious connection for such a signal?
16,466
Post some pictures of your handlebars and controllers, other members will help you.
16,466
yes, it does.
jokskot
156
47
75
Thanks to all repondents.
Reading round this, it seems I can achieve what I want with a bit of electronics - a transistor and maybe a relay. Selected parts on order and I'll report back reults once fitted.
