Replacement battery for 48V Woosh kit
Bluebouye
I have a 48V Woosh conversation kit purchased approximately 12 months ago. It has a 5 pin integrated controller/cradle on the down tube. I am after another cheap battery. Would any hailong battery fit this cradle? If not do people know what battery would fit it? Many TIA.
2,852
Bluebouye
There are different Hailong pin arrangements.
Pictures at https://forums.electricbikereview.com/threads/hailong-battery-connector-dimensions.54034/
They may also vary slightly in height, so if you have a tight fit with a shorter one then a taller on might not fit in your frame. The battery cradle is the same
Thank you. The height should be fine and I can work out if it will fit OK in the frame but the pins may prove to be a problem if not all 5 pin configuration batteries are made the same.
thelarkbox
1,667
517
oxon
Ebay, amazon etc can sell you replacement terminal modules for hailong style batteries and sleds. expect to pay a tenner for a male/female pair, somewhat overpriced, but i couldnt find it cheaper even from aliexpress as pnp bumped up the costs..
You will need a hi watt soldering iron (60w+imo) to desolder/resolder the connections to bettery and seld for the terminal blocks
Ha.. now i find em for a fiver!! go figure
Hailong terminal blocks on ebay
Bluebouye
Brilliant bit of information, thanks. This looks like the easiest way to ensure it would fit
Az.
2,170
985
Plymouth
It would be helpful to now which conversation kit did you buy from Woosh.
If I were you I would email Andy and as him some questions.
harrys
410
108
Chicago, USA
You do have to carefully inspect the pictures of your prospective Hailong replacement. There are different versions of the case/cradle being sold.
