They tried it on ES and sometimes one motor would cut at high throttle. Maybe it was specific to the type of controllers they used, so it might be worth a try. Another thing to try is to use a small microprocessor like a Picaxe or Geniie chip. You coould read the throttle signal then send it to two separate outputs. These chips can be powered off the 5v to the throttle. I'm going to try that on my next one.I have a question about dual thottle's though.
Would it not be possible to join the 2 signals wires and have one thottle and one sensor? the 0V would be commoned by the 0V from the battery. Just wondering if the sensor would sink current from 2 controllers ok? i think they are usually working in micro amps?
