Hiya, im reading and reading and just want s9meome cleverer than me to confirm.
1000watt rear hub
48volt
91 25r cells 7p 13s
Really want to seal the battery and controller away in my frame build and not worry about it from month to month, hense the 25rs over the 30qs figure they just wont heat up at all? would anyone be able to post a link to a buyitnow BMS, happy to spend proper money on it as dont want to be doubting it every ride.
Not sure on the specs of the controller either can you tell so as to recomend a BMS just from its casing? does the controller specs matter when choising a BMS?
Massive appreciation to everyone
Ps if anyone wants my pedal assist and brake cut offs.. PM, send me a stamped addressed and il post them to you. (Im not using them in this build)
Low
1000watt rear hub
48volt
91 25r cells 7p 13s
Low
