When I'm moving fairly quickly and power is applied to the motor then I get a cyclic rubbing noise as if the windings or the gears are rubbing once every rotation, I'm not sure how it compares to wheel rotation as I don't know how fast they are spinning. It doesn't happen at low speeds or if there is no power to the motor so I'm assuming the problem has to be between the controller and the motor freewheel, does it sound familiar to anyone?
Edit: it's a SB geared rear hub motor on a Wisper 905.
