I just recently changed my Swytch kit controller to KT 22A Controller Kit that I ordered off Amazon, and since it was difficult to find information on the correct settings for the new controller, I thought I would share them here. I bought a complete KT kit and replaced all the Swytch components other than the hub, it's really the only way to make everything work properly. This is the battery replacement that I used as well https://www.amazon.com/gp/product/B089NRZMWK/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
It doesn't matter which KT Display you use, the options would be the same.
Important info for Swytch hub:
- There is a 250-watt and 500-watt hub, but I believe the settings for both are the same.
- The hub uses 6:1 ratio with 16 magnets in it. (To determine P1)
- It has 1 magnet for the pulse signal (For P2)
- The rest of the settings are attached, but are my setting preferences, where applicable.
