Shimano Hydraulic brake with Switch £75
  • Start date
You have a choice of three connectors, including the Bafang one for BBSxx.
The photos show both left and right sides, but I'm not sure whether they're all fronts (short hose) - best to ask first.
https://www.aliexpress.com/item/Electric-Bicycle-Hydraulic-Disc-Cut-Off-Power-Brake-BAFANG-SONDORS-Pasion-Ebike-Parts/32749432485.html?spm=2114.8153825.cb0001.1.mneBXX&scm=1007.13409.76764.0&pvid=945ab5b8-d3cd-4443-9c40-6888a5b72753&tpp=1
I guess that's still a little steep for what's probably a £40 brake with a switch added, but it saves a lot of messing about.
Reactions: shemozzle999
17,348
I think the picture is of the front brake. The hose for the rear brake is a fair bit longer.
See the price? $95 + duty and VAT
awol
1,216
374
Looks neater than my attempt which took me quite a while from ordering wrong reed switches and wrong shape magnets to fit etc
Looks ok from the top as you can't see anything.
Finished them months ago and still not got around to fitting them yet though.
These are what I ended up using :-
http://www.ebay.co.uk/itm/Aleph-PS-3150-Proximity-Magnetic-Sensor-Reed-Switch-Perfect-Normally-Open-/121669184274?hash=item1c540c6b12
http://www.ebay.co.uk/itm/10-Magnet-Rods-3x10-mm-Neodymium-small-bar-craft-reed-switch-3mm-dia-x-10mm-/152468387757?hash=item237fd2f7ad:g:dkQAAOSwYshUZjXs
Reactions: JohnnyBBadd
8,797
Reactions: awol and Woosh
17,348
8,797
Also the same as the Oxydrive reed switch my kit.
5,786
There were a lot of reports of reliability issues with those switches, which were attributed to the type of hydraulic oil used, so do your research before buying one.
