I think it would be fun, interesting and a worthwhile project to fit a solar panel to sit over the rear panniers of my Kona Ute.
Here's a mock up using a bath towel to illustrate the idea. Size is about 70cm by 120cm. I would use lightweight tent poles to set the panel up facing the sun when parked.
My thinking is that I can only ride about 2 to 3 hours and still enjoy the journey. It's daylight about 5am and dark about 9pm just now, so if the bike was out in sunshine, lets say I only go to the beach on sunny days and it's 20 miles away, the panel could be charging when parked, whilst riding, at the beach and on the way home.
If it could work, then the aim would be to be able to tour along the coast, riding, solar charging and occasionally topping up when plug point available, but not depending every day on needing a charge point.
The bike is 24v, 250W motor and 13 Ah. I can probably get there and back on Eco mode, but not sure if my legs can still ride so far. So looking to top up the battery so I can do 40 miles along the flattish coast on standard level, plus a bit of level 3 on the occasional hill. I could also add a second battery sitting on top of the wooden rack top and under the solar panel.
konaworld
and more here First look at the Kona Electric Ute « « Bikes As Transportation Bikes As Transportation
Question is - can this be a reality? If it can, can I make it happen with the right help? Who should I go to to do it?
Thanks for help
Brian
konaworld
Thanks for help
Brian
