Solar panel charge ???
chris2014
13
54
hi
its possible to charge the bicycle battery with a solar panel when you ride ?
There is 10W-20W semi-flexible very light panels that the rider can have in his or backpack and that way get some extra miles of range in a sunny day.
Alan Quay
2,351
1,076
Devon
It's a nice idea, but it is 10w really worth having? You would be lucky to be putting 5% back in, and you would be carrying extra weight. This might even negate the benefit.
Better idea would be to get a bigger battery, and charge it with a solar cell that you don't have to lug about. Even that has it limits.
To put it in context: Assuming its summer, and the cell puts out 10w, for 12 hours (unlikely) that's 120 watt hours. If you have a 36v, 10 ah battery (360wh), and perfectly efficient charging system you could re-charge the battery in 3 full days.
I'n reality in the UK its more likely to be a week or three.
Sorry to be so negative, but that's just the reality of solar I'm afraid.
chris2014
13
54
the idea is to get extra miles (like the brakes regen system), not fully charge the battery.
But is it possible to directly connect a solar panel to the battery or you need lots more components ?
Alan Quay
2,351
1,076
Devon
Brake regen is probably not worth having either.
The reason I gave the illustration of the full re-charge is to put in context the tiny contribution this panel would make.
...and yes, you would need some extra components to make it work.
Sorry to be negative.
30,826
I agree with Mike, you'd be adding little distance, hardly worth the trouble and expense.
Assuming your battery normally lasts for a two hour continuous ride and the sun on the panel remains at maximum, that might give perhaps 2 extra miles at a typical 12Wh per mile in a theoretical ideal situation.
In a real world situation with the direction of the sun onto the panel changing and the brightness varying, probably more like one mile at best.
