Sourcing Tongxin and other components from China
frank9755
1,228
London
All these speed are for a maximum of 20 kph rather than 25kph so all a bit low.
This is what Tongxin specifies - probably based on the Chinese market (?) - but we all overgear to get higher speeds.
If I work out the motor required for my cytronex I get a figure of 192 rpm but that may be that I am not working out the wheel diameter very accurately. However it would perhaps explain why my bike rarely pulls me up to 15mph - more like 14mph.
More likely to be the slightly lower voltage of the NiMH battery. My 175rpm Tongxin in a 700c wheel assists to a bit over 16mph with a Ping LiFePO4.
AndyOfTheSouth
347
Hi Frank
Thanks for the link - apologies for missing it. I emailed Keywin and received an impressively fast response. He can supply the controller for $45 included shipping, but only the Bafang SWXK sensorless motor (180 RPM), not the Tongxin. This may be what I already have (I don't actually know) and am trying to fix. However, not only is it bigger and heavier than the Tongxin, it has rolling resistance.
Best wishes
Andy
Correction: have now googled Bafang SWXK and it looks different from the Bafang I have. It looks smaller and more Tongxin-like! Interestingly, it shows a cable with a local connector - an obvious idea and very practical, but strangely absent from mine.
The link is Suzhou Bafang Electric Motor Science-Technology Co.,Ltd.
I will try to find out more about it.
30,850
Andy, that 8fun motor is the latest version of the motor used in the eZee Torq 1 and Quando bikes. It's main difference is the stationary side plate centre with large diameter bearing allowing a side entry cable instead of spindle entry, rather like the system Heinzman use. It will still have the rolling resistance of the nylon gears though. About a half kilo heavier than the Nano and slightly bigger.
HarryB
1,317
London
Well a back of an envelop calculation I work out that for a 175rpm motor to be correct then the wheel diameter has to be 750mm. I think you have to have some balloon tyres to get up to that sort of diameter. A 700c wheel is 700mm when it has a 700X39 tyre on it but the cytronex have 700X32 tyres so less than 700mm.
So my calculations are:
192.19=25x1000/60x3.142x0.690
I can only assume that the calculation is based on a nominal voltage of 36V unless somebody can tell me where else I can be going wrong?
AndyOfTheSouth
347
In case any of it is of any use to anyone, here are the details of Bafang motors from Keywin Ge (ecrazyman@gmail.com).
SWXK motor price is $185 included shipping, the motor and controller are bought together, the total price is $215.
SWXK is the front motor for 26" wheel - Keywin can install disc brake but not a freewheel.
The rear motor model is SWXH – he can install a standard seven speed freewheel and disc brake but not the freewheel.
The price for either is $175 included shipping.
The motor is 36v/250w. If needed he can add pedal sensor feature for the controller.
I have simply taken these details from emails he sent me (very promptly). I have no idea about their value, etc.
daniel.weck
1,230
here are the details of Bafang motors from Keywin Ge (Keywin@eCrazyman.com).
I think his email address is Ecrazyman@gmail.com (Ecrazyman.com is not a valid domain name). Anyway, the best is to contact him via his eBay outlet (I'm waiting for his reply regarding a Bafang motor).
Cheers, Dan
AndyOfTheSouth
347
Thanks Dan, I did indeed email him on ecrazyman@gmail.com. He responded more or less instantly. I must have been dozing when I wrote the other address. Have now corrected it - thanks!
daniel.weck
1,230
Thanks Dan, I did indeed email him on ecrazyman@gmail.com. He responded more or less instantly. I must have been dozing when I wrote the other address!
I'm waiting for his reply.
On a positive note, I've actually just received a reply from Suzhou Bafang (Helen from the sales department), I'm thinking of purchasing a kit direct from them, and Helen doesn't seem to tick so far that I am not going to buy in bulk (I'm not a trade / reseller)...we'll see. In the meantime, I can ask for technical details about their newest motors.
By the way, I just got the "8-Fun" meaning: 8 is "Ba" in Chinese, so 8-Fun = Bafang ! :)
Cheers, Dan
30,850
Cheers, Dan
That's right! The number 8 is the luckiest number in China, and luck is more important a factor to Orientals than to us. The electronics company LG for example is actually the Lucky Goldstar company.
And "fun" needs no explanation of course. :)
daniel.weck
1,230
It seems that the Tongxin 24V 180W 80mm (260rpm for 16"20" wheels) can be purchased from Germany (no extra tax, straight-forward Europe shipping):
Google Translate
(some info there about the Suzhou Bafang 8-Fun SWXK as well)
daniel.weck
1,230
daniel.weck
1,230
I'm very curious about the "FWF" motor that these german riders seem to like even more than the Tongxin. Just like the Tongxin, it's a totally different technology than the usual geared brushless motors (Suzhou Bafang / 8-Fun, etc.). It's not a high-power motor (so it shouldn't slip unless it's really under stress), but seems to provide discrete torque under pedal-assist...if only I could speak German better than Google-Translate !
daniel.weck
1,230
FYI: Frank (the seller) has got Suzhou Bafang (8-Fun) SWXK units in stocks (36V 250W 255rpm), and Tongxin (24V 180W 260rpm). The FWF is not available. He normally adds 12 Euros for postage, but it might be a little more for UK delivery.
Google Translate
daniel.weck
1,230
