Hi Guys
I need a bit of help.
When arranging for the delivery of a new battery from sunlova I also ordered the controller which allows the fitting of a pedelec sensor (double hall sensor) see king-meter (the old controller had a very strange sensor that was impossible to fit). The new controller came with a dashboard (3 power mode) and a thumb throttle.
When I connected everything up I was disappointed to discover that nothing worked. The dashboard has a button to switch from pedelec sensor to the throttle. Nothing worked in either mode
So I dismantled everything and built it up again slowly to ensure that the connections were ok.
I discovered that when I connect the battery, controller and the thumb throttle only - everything works fine - good news to a point.
However when I connect the pedelec sensor again neither the throttle nor the sensor works!
The sensor has an led which I imagine should come on when connected but doesn't. Before I get back to sunlova I'd like to have some idea as to whats going on.
Is it the controller or the sensor that's causing the problem? It could either or both of course but maybe someone has come across this problem before.
I'd appreciate any help.
John
John
