Decided to do a little bit of movement on the bike with the controller setup etc.
Make it a little more stealth.
Any way I decided to take the controller araprt to find that the controller supplied was only rated at 6amp with a 13amp peak.
Possibly why Donna who I brought the kit of felt it wasn't that powerful.
On the other hand it means that I wasn't as unfit as what I thoguht previously
Either way the weakest part in this kit was the controller for getting the max out othe setup.
Least I guess with this controller and standard setup your never really gonig to get a motor or battery failure from to much power / draw.
Also would mean extended battery life and range (As you'd have to pedal more) which is probably why when I ride the 18miles to work I only ever use up at best 3.4amp hrs and at worst 4.4amp hrs.
Not a masssive issue really as I have a complete kit coming soon with new controller motor etc. But what this controller will give me is if I ever decide to run an over volt version of the bafang 350w kit I can definetly keep the amp's quite low ;-)
