You UK guys might know more about this display. I have used KT controllers and know how to wire in a speed sensor. The controller that came with the SW900 doesn't have a separate connector for speedometer. It doesn't show the speed when coasting. Might be a setup issue, but I think it needs a sensor.
There might be an input on the controller circuit board, but I'd have to just guess and probe by trial/error. However, the docs for the SW900 says it has an extended function for speed sensor, as well as lights, etc, but I only have the typical 5 pin plug with power, Rxd, Txd, etc. I've googled and found a picture of the SW900 with an extra two pin connector, but no description.
Has anyone seen this display with an extra connector for a speed sensor? If so, then I'd open it up and look for the inputs.
