Synergie Mistral commuting - 5 days, 115 miles
dazzie
129
Hi all,
Last week was my first week of commuting between Bristol and Bath each day (roughly 11.6 miles each way) on my little Synergie Mistral.
I was a bit worried that I wouldn't be up to the job but with the Mistral's help I managed to ride in every day and it was only on Thursday and Friday that my legs were stiff and sore upon waking (though last night they were so sore I could barely walk!) - pretty amazing given that I haven't cycled much for years and am very heavy (roughly 21 stone) and unfit. Electric bicycles are incredible.
I averaged over 14 mph, taking roughly 49 minutes each way. There are some mean hills on the route and so I spent quite a lot of the time recovering from each hill by allowing the motor to tootle me along (Mon-Thu I was on max throttle most of the time, even on the flat).
Mon - Wed I took my spare battery with me, changing it over before the trip back. This was because the power meter would drop to 4 out of 5 bars on the way in and I could feel that power output of the motor was dropping. The first bar would actually start to flicker off after about 6 miles. I am a heavy guy though and was abusing the bike quite badly.
Thus - Fri I took the charger and this helped a lot with reducing the weight I was carrying (and I went from two panniers to one - Ortleib Back Roller Classic - very impressed with them) - most important as I was starting to flag.
One thing I have really been struggling with is hand pain - after just a few minutes my hands would be agonising and frequently I had to take my hands off the bars (one at a time!) to allow the some respite. This posed problems with my right hand as it holds the throttle open. I'm hopefully getting a stem raiser fitted today which might alleviate the pain a bit. Anyone got any other suggestions (comfy grips or anything?)?
My local bike shop may have my Schwalbe Marathon Plus tyres in today (fingers crossed!) and I'm hoping they will both remove my fear of getting a puncture on the way to Uni and reduce the rolling resistance of the bike (which seems to be very high at the moment).
Another issue is that the motor keeps sticking on - it tries to drive even when I'm not pedalling or turning the throttle. Very strange and a bit of a problem if I don't remember whilst getting off it (dismount, release brake, bye bike!)!
Oh, and the brake cables kept stretching. I had to adjust them three or four times each before they settled down (though are still stretching a bit). The mudguards are a bit flimsy and rub on the tyres occassionally and I broke the chain guard by catching it with my trainer one day. Minor issues, really.
Thursday and Friday I wore lycra 3/4 bib tights and wow what a difference to wearing combats or jeans. Fantastic. Highly recommended. Bit strange not wearing any underwear though. :eek:
Overall I am very happy indeed. I am cycling to Bath virtually as quickly as you can drive there (in rush hour traffic), I'm getting lots of exercise and hopefully getting fitter by the day. Long term (once I'm much fitter) I hope to get a non-motorised road bike to commute on but without my cute little (too little, if I'm honest) Mistral I'd be lost.
Daz
Vikki
442
ROFLMAO.
Sounds like you're really enjoying your new bike. I got the same problem with my wrists as well, I find I'm holding the grips a bit more lightly. Like you I'll have to see what I can do about that.
best regards.
Vikki.
Hi all,
Daz
Another solution, is to change your handle bar to a BMX type or 'cow horn' style handle bars. They relieve the stress in your arms by putting you in a more upright riding position, which means that there is less weight bearing down upon them.
The handle bars I have described come in various lengths. Please see the attached picture as examples. Hope this helps.
dazzie
129
Just a quick update folks.
Two weeks in and compared to last saturday I'm in much better shape - I can actually walk!
I had a pair of 26 x 1.35 Schwalbe Marathon Plus' fitted on Wednesday afternoon and I wish I'd had them fitted sooner - I am able to go up hills a gear higher, downhill 3.5+ mph quicker on the steepest hill and am able to cycle at 18+mph on the flat unassisted (compared to about 15 mp before). I knew thinner tyres would improve things but I had no idea by how much! I increased my average speed over the 11.8 miles to 16mph from 14.9mph.
Thanks to the tyres the bike behaves much more like I had hoped it would.
I've worn out the front and back brakes in two weeks (this will get costly if it carries on like that) and I need to spend the weekend doing some maintenance on her but together we've done over 250 miles in two weeks and I couldn't be happier with my Mistral (and it gives all my new Uni friends and tutors a good giggle *harrumph!*).
Cheers,
Daz
Kal
84
Cheers,
Daz
If you want to go even faster downhill then try switching the Mistral's battery to "off".
dazzie
129
Thanks both - do those pads fit the standard Mistral blocks?
Daz
PS 43mph!? Where were you? The Alps?!
Kal
84
After reading above, about brake block wear, I thought I had better check the brake blocks on my own Synergie Mistral. No problem.. I've done over 1500 miles and they look good for another 1500 miles. They are "Promax" make as fitted from new. I make use of the brakes a lot to slow me on the steep hills where I live. I'm only about half the weight of you Dazzie, so I guess that's the reason you are getting more brake wear. I don't know whether it's down to good luck or me being a light rider, but I haven't had any problems with my Mistral. I haven't changed the tyres because I can't see anything wrong with the standard ones and the tread still looks good. I love the soft saddle many have changed. As for maintenance.. I've had two back wheel punctures and adjusted the brake cables once. So, for me at least, the Synergie Mistral is a cheap (I paid £450 delivered new last March) reliable e-bike.
Mussels
3,207
Crowborough
Daz
It's quite easy in the right places, there's one hill I go over in London and if I just coast down sitting upright I exceed 40mph.
There are some faster hills but they have bends and I'm still on my snow tyres, they will have to wait for a speed test. :(
30,849
Ditto, oddly enough that 43 mph is my maximum speed on a local hill I coast down at speed quite often.
rog_london
764
Harrow, Middlesex
Down through Hampstead on Saturday afternoon, no doubt! :D
Rog.
