THe 11 tooth gear was crunching under pressure
stevebills
443
I took my bike to Andy at the bike shop near me because the high gear was crunching under electric power and he set the derailleur up and it was indexing great and I tested it and it still crunched so we changed the cable which looked slightly worn and tested again and same thing it crunched and then Lenny came out of the shop and had a look and put the bike in top gear and started to pedal it down the path and I spotted the chain jumping off the teeth on the high gear.
He had a 12 tooth he had ordered for a customer and I borrowed it and swopped it with the 11 tooth and I tested the bike it was fine so now we have ordered a replacement Shimano HG40 11-34 speed cassette at a bargain price only £19.99 delivered :)
stevebills
443
I am guessing (Flecc may put me right) that the high gear will always be first to break as its used the most and being small has more chance of slipping the chain :)
HarryB
1,317
London
Did you change the chain and not the rear cassette? Sometimes you get that happening if you allow a worn (stretched) chain to wear out the sprockets. You can get away with just a new chain if you change it regularily and use a chain stretch indicator tool. Yes it is always the smaller sprockets that wear first.
stevebills
443
Chain is fine it was checked with calipers and chain works on new 12 tooth gear and all the other gears :)
HarryB
1,317
London
OK - very odd that it would not wear and the sprocket would. At least you have a cheapish fix.
HarryB
1,317
London
It is just that it is usually the chain stretching that wrecks the sprocket or they both wear together beautifully until the floppy chain breaks or becomes a nuisance!
30,803
I think 11 tooth and smaller rear sprockets are always questionable, but especially so when the motor drive goes through the transmission as well.
stevebills
443
I was thinking the same and the power of the motor must wear the gear down
quicker :)
stevebills
443
I think the SRAM PC971 chain must be strong :)
