50 miles on throttle alone....is that due just to 48 volt battery ?..if so why are that size and distance not around already at a fraction above normal cost ?
Not just 'cos it's a 48 volt but I suspect because it lists it's capacity as 20 amps as well! Bear in mind a replacement battery of that spec will also cost a small fortune, (correction, scrub out: small). Although you would think it would 'only' achieve 20 to 25 miles at the listed speed of just under 20mph.
As luck would have it, I've just finished watching a YouTube clip, a (British), bloke videos himself on a 500watt e-bike (Cyclone motor conversion I think), travelling up to between 25mph and 32mph using only a
24 volt battery rated at 10 amps.
He complains he's only getting about 11 miles per charge!
The 500 watt bike in Blew-it's clip lists it as capable of 19.8mph RESTRICTED, (USA regulations). So if it was possible to derestrict it, then 25 to 30mph might be achievable too, on that 48V 20amp battery.
I've been looking at a couple of 'cheap' 500 watt kits on eBay rated to run with a more affordable 36 volt battery, but without any knowledge of the motor manufacturer, I'm just looking. Would suit a heavy rider like me IAMO. A rear wheel set-up would slot straight into the Salisbury. So by the time my Salisbury battery reaches the end of its useful lifespan and I come to splash out a couple of hundred, I can pause to reconsider before purchasing a replacement if - I hope, some brave souls have already taken the plunge, bought a 500 watt kit and reported their findings on here. Purely for off-road use you understand. Yes, off-road use only, I hope that's clear. Me? Use it on the roads? No, no, noooooooooo... You do believe me don't you? (If you did see me on the road with a 500 watt e-bike it would most likely be somebody else who resembled me as everyone knows I'd only use it off road). So, glad that's sorted then.
Riding on a 500 watt e-bike conversion -
YouTube - 500W Electric Bike Kit Motor E-Bike Conversion - Part 2
(He covers 2 miles at an average speed of 22.8mph according to his c/computer - on UK roads, so yes that makes him
an outlaw)
