Hello,
I ask your kind support for the issue in subject.
In my ebike controller I found 2 connectors with 3 wires:
1. Yellow, Green and Red
2. Black, Yellow and Red
The first seems a throttle connection as bringing 5V on the Green the motor starts running (Red is a 5V and Yellow is to ground). While does not trigger the motor with the PAS square signal. The Green is terminated to H0 on the PCB.
I need the connection to the PAS. On the other connector I measured, when powered up, 5V on the Red (Black is to ground) and on the Yellow 6V (not stable). The Yellow is terminated to VP on the PCB. Could be this one the connector for the PAS? I was not confident to try and risking to burn the controller...
There is a way to discover it?
In the picture attached the controller and the (2) connectors.
Many thanks!
Eugenio
Many thanks!
Eugenio
