Throttle and pedelec stop working on bumps
C
Cyclezee
Was it a nut bolt or a self tapping screw cwah? It looks like you have removed it, just be very careful not to touch the terminals.
cwah
3,048
179
www.whatonlondon.co.uk
removed it completely here:
Have to be careful lol
cwah
3,048
179
It was just 1 screw I had to remove to access it. Shall I use a plier to tighten it?
C
Cyclezee
OK cwah, with each terminal in turn carefully and gently close the gaps slightly using an insulated pair of pliers or similar tool.
Treat it like you would an unexploded bomb:eek:
cwah
3,048
179
Ok, just did it with my plier. Repackaged everything into the battery box now.
I'll try tomorrow to see if it's fixed.
cwah
3,048
179
Noooo! Still not. I resoldered 1 connection and will try another one soon :(
cwah
3,048
179
Finally solved the problem. The controller was moving inside the frog box.
I just glued it to the metallique bar to prevent it from bouncing. Now everything is fine :)
C
Cyclezee
That is good news cwah,
Not wishing to say that I told you so, but I told you so;)
"If there is no intermittent cut out of power when stationary and from what you said in a previous thread I suspect the controller.
How old is this kit cwah, the battery terminals look fairly new and clean?
What make is it and where did you get it? .
What happen to the controller, how did the case break and do you have a photo of it?"
