Tied my self in Knots
4,036
Had this Freego 2014 Folding bike delivered(See 1 Pic)......the Front light was loose..so not sure what I did but tied myself in a right mess.see Pics 2 & 3........Tried turning Handlebars but it's not working....HELP
What exactly is the problem you want to solve? What's not working?
Seanoge
190
14
80
Gulval, Penzance
Yes, and I don't know how it happened........or how to undo it.........I took it for a short dive.all Ok.....then stored in shed.....took it out to take it for a service....saw front light was loose..so fixed it with a bolt....then found all my cables were tangled......
Sparksandbangs
208
68
Is there a quick release that allows you to pull the entire stem out?
If so release, pull out, untangle, replace stem and lock in place.
8,792
One would say the solution isn't rocket science.
Seanoge
190
14
80
Gulval, Penzance
To turn the handlebar I would have to remove a bolt on the Cablebox, and loosen 2 Alan screws. I did none of this at the start. I'm completly puzzled how I got into this mess. You cannot pull handlebar out as Cables wont' let you
Seanoge
190
14
80
Gulval, Penzance
The only thing I did was fix the Front light to its holder.....it was hanging loose.......If I unhook it again.....I'm still left with the problem.......I just can't explain it....
.Later I'll try turning the handlebars....
chris_n
828
477
63
Niedeau, Austria
No you wouldn't, there is nothing stopping you turning the handlebars and front wheel.
thelarkbox
1,643
511
oxon
has the front wheel been twisted around 360 degrees in err perhaps, shoving into a cluttered shed could force a mud guard under a cross beam facilitating the twist?
try rotating the front bars/wheel assembly in the direction that reduces tangle and give it a modicum of oomph if a mudguard presents a problem ;)
