Deleted member 33385
How many of you Loctite your motor bolts? I noticed all of the bolts in my kit arrived with a little band of blue pre-applied loctite-like threadlocker. The bolts were a bugger to take off later on... Should I Loctite them again or is that going to cause a buildup of Loctite debris? I did notice squeaking when they were being screwed back in. Should I try and dissolve the previous Loctite with acetone? It's a vibrating motor, so Loctite Threadlocker seems sensible to apply to bolts. In the event of bolt threads gradually getting stripped through vibration, I don't fancy attempting to rethread holes in the motor casing to a larger size... ordered Loctite... I can't recall where my thread tapping kit is, hope I won't need it. It's the threads on bolts 1 & 2 which look as though they are wearing away a little via motor vibration, also the two nuts in the area marked 3 - the outer one had a very small amount of wear, which made it tricky to put back on. I don't like it... this wearing away of motor nuts and bolts...
In the second pic: wear near the top of the bolts. Loctite can't arrive soon enough...
