Tongsheng TSDZ2B 48V 250W on Sale at Woosh
17,259
From Sunday 8th June, we lower the price of our 48V TSDZ2B 250W to UK's lowest £270 including UK next business day delivery!
Conform to EN15194. Motor rating: 250W nominal.
Simple and neat plug and play wiring.
Torque sensing system.
Powerful high torque 48V motor.
VLCD5, torque sensor
Installation in 6 steps
Download and read the TSDZ02B Installation Manual
Download and read the VLCD5 LCD Manual
1) Remove your bottom bracket and front derailleur
2) Insert the motor and install the motor hanger, fasten the bottom bracket.
3) Install the battery.
4) Install the LCD.
5) Connect the waterproof cable and the battery cable.
6) Install the thumb throttle and the brake handles.
Specification
ITEM NO.TSDZ2B
Size (L x W x H)134 x 156 x 182mm
(CL/B)50-53.5mm / 68-75mm
Rated Power250W/350W/500W
Efficiency (%)≥80
Reduction Ratio41
Wheel Size (Inch)Optional
Rated Voltage (DCV)48V
Max Torque (N.m)90NM
Weight (kg)3.6
n0(Rpm)100
Power Assist Ratio36%~300%
Pedal SensorSpeed and Torque Integrated
Shaft StandardJIS
Noise Grade (dB)<55
ThrottleOptional
E-BrakeYes
IP Level / Salt Spray Test65/96
CertificationCE/RoHS/EN 15194
Bike RecommendationE-CITY / E-TOUR
matthewslack
2,430
1,608
Hi Woosh,
What's the background to this? Is there a change coming, or just stock levels?
17,259
Just stock level.
We are phasing out TSDZ2B in favour of the TSDZ8.
We still keep spare parts for servicing.
Reactions: matthewslack
