too much torque
flux
27
10
49
scotland
I don't think my smallest sprocket is surviving the torque of my motor very well. Is this common on e-bikes?
flux
27
10
49
scotland
Hi,
Its a Liberty Stealth, which i believe is a U.S version of the ProRider e-voyager with some minor tweaks like disc brakes.
Wisper Bikes
6,316
2,279
70
Sevenoaks Kent
I though so much from the image. I have never seen this on a hub drive bike, there isn't any power going through the chain drive apart from the rider's. It's probably down to poor adjustment.
flux
27
10
49
scotland
Everything seems pretty well aligned and there are no odd noises or rubbing. I thought that too. its got a lot of torque, but the stress on the sprocket is due to me pedalling not the motor.
flux
27
10
49
scotland
5th gear is looking a little bit twisted too, but nowhere near as bad as 6th. The rest are fine, but its fairly rare i'll ever drop into 4th.
Wisper Bikes
6,316
2,279
70
Sevenoaks Kent
It looks well used, so maybe time to change the freewheel or cassette. Sorry I cant be more helpful but I am sure it has nothing to do with the bike being electric.
flux
27
10
49
scotland
Will probably have to replace it at some point. Its not slipping or anything. do you think it will snap the chain?
They only have 6mths of use on them so not a great lifespan.
Artstu
2,421
925
thats the one.
In that case the only torque load on the cassette is from you.
I guess Ian Stannard could produce too much torque, you're not Ian are you?
https://www.strava.com/activities/597034291#14541649296
I'd put a decent chain on at the same time, because the bike is so long a bike shop will cut one off the roll for you, most boxed ones could be too short.
flux
27
10
49
scotland
haha no, not quite. It does require a lot of effort and perseverance keeping it anywhere near 20mph though.
If i'm going to change the sprockets/chain i'd ideally like to increase the gearing at the same time. gears 1-4 are never used and 6 spins out too early.
30,826
Your chainwheel is quite small, very small by my standards, forcing you to the smaller freewheel socket to get high enough gearing. Hence the spinning out too early you report.
If you change the chainwheel to one with many more teeth you'll be able to use the larger rear sprockets much more and spend far less time on the smallest one which wears the fastest.
Reactions: D C, RobF and Woosh
RobF
4,732
2,312
Looks like 26" wheels which will give lower gearing than 27.5 or 29er.
The OP is probably spinning a fairly high cadence at 20mph.
As flecc says, a bigger ring on the front would be a sensible mod.
