It's not really helpful for several reasons.
First is that most manufacturers don't give a figure, so comparison is impossible.
Second is that bikes that drive through the gears like the Kalkhoffs with the centre Panasonic motor unit can apply their torque and power combination at varying speeds to make climbing almost any hill possible.
Third is that on such low powered motors as e-bike ones, the maximum torque is only useful when it coincides with maximum or near maximum power.
To illustrate that last point further, the maximum torque on a typical sample legal hub motor exists from a standstill to about 9 mph, but the maximum power gradually increases from zero at a standstill to it's maximum at about that 9 mph. So you can see that below that 9 mph the power vanishes quickly, and above it the torque diminishes, leaving an optimum of 9 mph to climb a steep hill with the best of torque and power.
The Kalkhoff type mentioned can use the gears to apply that combination of maximum torque and power at a speed to suit the hill to climb, instead of only having it at one speed as in the hub motor.
Finally the added complication is that the 200 Watts or 250 Watts quoted is meaningless, being a notional figure applied for compliance with the law.
The Powacycle Salisbury and eZee Forza are both nominally 200/250 watt motors, but the Powacycle gives a maximum of just over 300 Watts gross power and the Forza one gives a maximum of about 700 Watts, well over double. The best judgement comes from reviews by owners and magazines where an opinion of performance and hill climbing can be gained, and of course the knowledge obtainable in this forum is also a reliable source.
