I've recently invested in a trailer to increase load carrying ability, but have run into a snag. The hitch is designed for a 10 mm back axle, whereas with a hub motor, the axle is 12 mm. I've drilled out the hole in the hitch to fit the axle, but then the axle nut is too big to fit in the recess on the hitch. I've machined a spacer to effectively fill in the recess. Can anyone see a flaw in my cunning plan? How do others on here overcome this problem?
