trying to find twist grip throttle with juilet connecter
footpump
713
75
76
hi all my yosepower/elife shop rear kit comes with a thumb throttle with juilet connections as are all the other
items.
I have looked on ebay but cannot seem to find a twist grip throttle with juilet connection
anyone have any links to such a throttle
5,786
You may need to buy a Higo connector and solder it on yourself.
8,750
I have a RH full size twist grip but have a feeling it may be a red Julet/ reed switch though, I will have a look and see tomorrow.
footpump
713
75
76
thanks all the one above is out of stock.
I found another on ebay and have ordered but afterwards noticed it has 6 male pins rather than 3 on existing thumb throttle.
I wanted one with on/off switch, as I tend to hold left/right handlebar grips when mounting or dismounting the bike
8,750
Any good.
With throttle lock.
Never been raced or rallied :p.
8,750
The throttle is 3 pin julet, the red switch activates throttle on or off.
It's plug and play and simply replaces any 3 pin thumb throttle..
Julet's
2 pins red
3 pins yellow
4 pins blue.
Reactions: D C
footpump
713
75
76
thanks nealh I got a reply re the six pin throttle was not suitable so getting rebate .
if it will fit the yosepower 350w juilet cable as we both have same kit I will buy it of you but have no idea on the pm side of things thank you
8,750
It will fit and work, as it works on my dual voltage KT & a Lishui controller.
For PM select the envelope next to your name when logged in on the header bar at the top of the page.
In the new screen select new conversation and select/hype the recipients name in the participants pane.
