TSDZ2 "Brake Error"
bpratl
9
Gloucester, MA, USA
TSDZ2, 860C, 52V, OSF V20.1.3.....Just got a brake error after one year of no problems. This started after a recharge to 58.6 volts and the error occurs with or without the brake cables connected.
I can access the menu, and all looks good and normal accept I don't get a Voltage reading on the display and the motor is locked. Trying new cables and upgrading OSF to V20.1C.4 did not help.
Is there anyway of testing or bench checking the controller?
16,494
bpratl
9
Gloucester, MA, USA
not without proven working LCD and cable.
I did try a replacement Display, with the correct firmware, and checked the cables for shorts/opens and I still get the brake error. Everything has been working flawlessly for the past year, until this problem.
16,494
even after you unplug the brake sensors?
16,494
Unplug the speed sensor to see if the brake error goes away. If it does not,then your controller is the source of the error.
bpratl
9
Gloucester, MA, USA
Update, I finally made time to replace the controller, add thermal pads to the motor, update OSF V20 to .4 and now everything is back to normal. The controller was the culprit, but I not sure if my shutting off the battery first caused the "Brake Error" failure or just a defective controller. There were no visual burnt components on the controller.
Reactions: Bikes4two and Woosh
Bikes4two
900
401
Havant
Update, ............ There were no visual burnt components on the controller.
I suspect that for what ever reason, the micro controller itself can become firmware corrupt or electronically fail and simply stops working.
I have no proof that this is the case but my installation just stopped working after around 2,700km and shortly after I'd loaded v20.1c.2 for my vlcd6 setup - coincidence or not, I really couldn't say, but I could not communicate with the controller with my laptop, so that was it until I installed a new controller.
