I'd be grateful for any advice.
I have a Lafree Twist Lite and recently it has been producing a clickety grinding sound from the the pedal / bottom bracket area when pushing down (without power) on the right pedal.
I changed the pedals hoping that doing so might cure the problem - but it didn't help.
The power assist still works perfectly - in fact there's less noise when using it. (I guess because it's taking some of the strain off the crank when pushing the pedals round?)
Do you think this is a problem with the bearings inside the motor case?
I've looked at Flecc's site (that's one terrific resource - thanks!) and it looks as though they can be replaced, but can I ask
- is my diagnosis likely?
- are the parts for repair still available?
- any suggestions for a repairer in or near Birmingham (UK!) that could help?
- failing that is it difficult to effect a diy repair?
With many thanks for any advice.
