tyre pressure
electric.mike
342
49
grimsby
what tyre pressure do you run at, i have still at the moment got the standard e-bike tyre on all our bikes, they quote 40-65psi also to avoid another post later i want to change to the marathon plus puncture resisting what pressure for these please.
mike
Nick
152
I run at the manufacturer's recommended pressure - 75psi on the rear Continental Sport Contact and about 85-90psi on the front Continental Ultra Gatorskin.
30,813
I run the Kenda tyres on my Torq at around 45 front and 50 lbs rear. I'd prefer them a bit harder, but the unsprung weight of the front hub causes too much hammering at the front.
The large section fat Kenda tyres on the Quando at 45 lbs.
On the Marathon Plus 26" x 1.75 on the Twist I use 50 lbs.
Catalogue for Marathon Plus gives these pressures:
26" x 1.75 and similar: 45 to 70 lbs
700 x 38C (Torq size): 50 to 85 lbs
and warns do not use outside these pressures due to special construction.
