was the largest nimh cell that exists?
giguana
216
this is a bit on the theoretical side-could they make some big cells like car batteries?
Ian
1,333
Leicester LE4, UK.
The Toyota Prius hybrid petrol-electric car uses NiMh batteries for short term energy storage, I have no details but am sure that they are of a much higher capacity than a typical car battery, especially considering the fact that they are lightly loaded to maximise life.
On an even larger scale one variant of the GM EV1, a high performance electric vehicle designed to comply with proposed Californian zero emissions legislation, had its 100kW motor powered by a large NiMh battery.
And on a truly massive scale there is the Brush-Hitachi diesel-electric hybrid locomotive currently in its prototype stage. Despite having spies in the Brush factory I still don't know the battery chemistry but NiMh is a possibility, I am however told the battery and management system occupy an entire railway carriage and have a maximum output measured in megawatts.
If this massive battery is indeed NiMh then the quantities of materials used in its manufacture go some way to explaining the world nickel shortage.:D
As far as I know the largest readily available cells are F size, a little larger than the familiar D size.
EDIT. I have discovered that the Brush-Hitachi locomotive uses Li-ion batteries with a total capacity of 48 kWh, weighing 1 tonne and able to deliver a peak power of 1 MW. Life is estimated at 8 years. I wonder at what age the cut-outs will start.:D
giguana
216
Brilliant! it may possibly be a gas-electricity conversion reactor, there was one on television that looked like a giant radiator with a series of plates that turn something like compressed gas or hydrogen into electricity, it was about the size of a train carriage and they were showing it because it was the first "giant battery" to power an apartment block. that said, with a bike trailer on the back of a bike it would be possible to get a battery that does 100 miles:)
Jeremy
1,010
Salisbury
The Prius NiMH cells are small prismatic case cells (at least they are in my '05 Prius), with a capacity of only 6.5Ah (most car batteries are around 40Ah). The voltage of the pack is 273V though, so there is plenty of power available.
The battery in a hybrid isn't required to drive the car for any length of time, it's only there to even out power demand, by absorbing excess and delivering a high peak torque, primarily for pulling off and accelerating. This allows a big car to get away with a small engine, one that runs on a modifed Atkinson cycle (which would be unusable with a conventional transmission). The Prius will only cover 2 or 3 km on battery power alone.
Jeremy
30,792
It does have one advantage over us, it doesn't have to climb steep hills.
Very steep in railway circles is something like 2% (1 in 50). I think my Li-ions would last well if that was the steepest I ever faced.
Ian
1,333
Leicester LE4, UK.
Thanks for clarifying that Jeremy, I was assuming the battery would be of high capacity to provide the high peak power demands. In fact the Hitachi hybrid rail traction system also uses a battery with a surprisingly small capacity relative to the high peak power demands, if 48kWh can ever be called small!
But it doesn't have pedals either Flecc, so no passenger contribution:D.
On a serious rail related note perhaps the fare increases announced today will make electric cycling more attractive to some commuters.
