Waterproofing
Paultr
86
32
71
As mentioned on another thread I have just installed a rear hub kit. How do people waterproof their wiring - are the plugs themselves good enough or should I use some self amalgamating tape ?
In fact, is it wise to avoid using the power during heavy rain and just rely on human power ?
17,270
hub kits don't suffer much if at all from water. You don't have to do anything, other than drying your bike after riding in the rain. The LCD is a bit more exposed, so keep the glass at an angle for the water to run off.
CD kits suffer much more from water because the controller is inside the motor which is mounted quite close to the road surface and often gets sprayed if not immersed in puddles. Water can also find their way inside the CD motor through the bottom bracket.
DynatechFan
215
70
t'North
I used silicone grease from a diving shop - its a bit like vaseline but rubber and plastic safe and sheds water. Put it in the axle ends as well as wiring, battery charging socket etc
Did but some adhesive heat shrink (the properly waterproof stuff) but never got round to fitting it
BG bicycle
99
17
Bulgaria
I’ve just opened up my DD, and soaked the windings using an electrical spray that claims to repel water. After that then sprayed the windings with a insulation lacquer varnish.
Was an intention to add mineral oil. However, it’s yet to arrive.
3F53B390-D271-4A43-A9A1-4DE4F2D8DD88.jpeg CFD8175A-2016-446D-A060-8C2733050768.jpeg
  • Useful
Reactions: LeighPing
danielrlee
1,400
726
Westbury, Wiltshire
torquetech.co.uk
  • Useful
BG bicycle
99
17
Bulgaria
You might want to put a hold on oil cooling and look into using ferrofluid instead.
http://www.ebikes.ca/product-info/statorade.html
That ferrolfluid sticks to the magnates if I’m correct? What’s in ferrofluid to make that happen? Metal? Abbrassive ingredient?
Just collected the oil and it’s going in although only a small amount. Good enough for industrial transformer and motor cooling.
danielrlee
1,400
726
Westbury, Wiltshire
torquetech.co.uk
Don't get me wrong - oil cooling works a treat. It's just that the volume required is many orders of magnitude greater than required with ferrofluid and this creates unnecessary drag. Additionally, keeping the oil on the inside of the hub is a losing battle.
Ferrofluid contains nanomagnetic particles, far too small to abrase any of the motor components. The specific formulation is extremely important when it comes to this application. I'm fairly sure that the formulation used in 'Statorade' is Ferrotec APG1110.
Justin, the pioneer of ferrofluid hub cooling has tested motors for 10's of thousands of miles without adverse effects. The only concern might be the waterproofing measures you have already applied.
See the following thread for further information:
https://endless-sphere.com/forums/viewtopic.php?f=2&t=48753
BG bicycle
99
17
Bulgaria
Seen a few ferrofluid reviews majority positive. The oil leakage issue is partly addressed with use liquid gasket.
I applied a lacquer thus the clearance gap between stator and magnets now less. Perhaps this will inhibit the application of ferrofluid?
I’ll keep the product on a list, a maybe for the next build. The present build is a prelude to another Ebike, something more suitable for off-road and with a branded more robust hub motor.
danielrlee
1,400
726
Westbury, Wiltshire
torquetech.co.uk
I’ll keep the product on a list maybe for the next build. The present build is a prelude to another Ebike, something more suitable for off-road and with a branded more robust and hub motor.
The exit route almost impossible to stop is via the motor cables. Give it time and you'll find that oil wicks through the wires via capillary action.
The lacquer won't stop the ferrofluid from working, but there has been anecdotal evidence to suggest that the base oil can react with some conformal coatings. The end result isn't that serious though. The conformal coating can dissolve, which gums up the ferrofluid, requiring removal from the hub and application of a fresh batch.
Mind you, I suppose a problematic conformal coating might suffer the same fate with mineral oil cooling.
Reactions: BG bicycle
BG bicycle
99
17
Bulgaria
01F92D4E-FB13-433E-AE69-A37A6F974A15.jpeg The oil is in and a huge difference when free wheeling and when pedalling. Not that I do much of the latter, although the ease of turning that hub is greatly improved.
No oil leakage either.
Paultr
86
32
71
Much of this discussion about cooling goes above my head. I think I read somewhere that Statorade is for non geared direct drive hubs. Don't know if this is true or not but in any case would someone who understands all this briefly explain it for dummies and would I, as a geared hub owner benefit from any of this technology ?
Many thanks
Paul
17,270
no need for coolant.
You can ride for hours and your motor is not even warm.
The geared hub motors do not suffer as much from overheating as direct drive motors because they are much more efficient at climbing hills compared to direct drive motors.
Higher efficiency means much less energy is converted to heat, there is no need to worry about cooling geared hub motors.
danielrlee
1,400
726
Westbury, Wiltshire
torquetech.co.uk
Many thanks
Paul
Additional cooling of a motor is required when you want to push the power output past what can be sustained with natural cooling only. It is nonsense to state that any given motor type does or doesn't need it. If you want to eek the maximum performance out of any motor, it'll need additional cooling.
Ferrofluid works by bridging the gap between the motor windings and motor casing, providing a clear path for the heat to escape into the passing air. Direct drive (non geared) motors have a simple heat path, with only a single gap between the windings and magnets, which are coupled directly to the motor casing, so ferrofluid is extremely effective here.
Due to the complex heat path found in geared motors, ferrofluid is not sufficient to bridge this gap and therefore brings no benefit in cooling. An alternative (sealed method) for geared motors is oil bath cooling as used by BG bicycle above.
17,270
Paultr has an MXUS XF08C motor and a Lishui 17A controller.
That kit does not need coolant.
danielrlee
1,400
726
Westbury, Wiltshire
torquetech.co.uk
I certainly agree that a MXUS XF08C doesn't require additional cooling at 17A. That's not to say that it wouldn't still be beneficial in specific scenarios though.
If you were to fill one with oil, you probably be able to reliably run it at 30A. What's not to like (apart from the inevitable mess of course)?
Just to add that the discussion about cooling wasn't really directed at the OP, more a response to a tangent earlier on in the thread.
BG bicycle
99
17
Bulgaria
If your hub motor holds the oil then anything that isn’t messy or going to create one and assists cooling is a good idea.
The bicycle I ride on with the motor 95% of the time steady 25-30kmh and although I’ve found no problem with heat, include the controller, the mineral oil has most certainly reduced drag. I do pedal on hills unless commute to town -one steep long incline- were power consumption from repeated travel is known.
The biggest killer of all electrical items is heat. If are able to install additional cooling method(s) then it’s advisable to do so. As for my own experiment time will tell.
BTW, Woosh, great name.
17,270
the MXUS motor has an internal clutch and gearbox with nylon wheels.
Do you still maintain that Paul should use coolant?
chris_n
814
475
63
Niedeau, Austria
I bet I could melt the gears without any problems. Which motor type should I use on ebike.ca to model the XF08C, AN XF07 only shows an efficiency of 64% with a 17a controller at 10% gradient with a 100kg load. That means 36% going to heat (150W), I'm sure a hub motor can't dissipate that much heat energy for very long!
17,270
you can use XF07 to model the XF08C. They are similar enough.
The motor can dissipate 150W OK, there is a considerable laminar flow of air around the motor. On some motors where the emulator has a heat dissipation model like 9Continent 2705 DD motor which in the same condition has a yield of 57% and overheats in 26 minutes. I reckon the XF08C would overheat in roughly 30 minutes, travelling at 10mph, that's a 5 mile long climb.
danielrlee
1,400
726
Westbury, Wiltshire
torquetech.co.uk
I've never said that Paul (or anyone else for that matter) should use coolant.
I do maintain that additional cooling will allow a motor run at greater power levels or loads than it was originally designed for, whatever the motor.
