What does the trade use ...
danfoto
433
42
Sarfeast England
by way of a repair/maintenance stand when it comes to step-through pedelecs? We have a cheapo stand from Lidl which works well enough with bikes which have a crossbar, but I was just wondering what the trade uses instead where there's no crossbar ...
3,359
Weightlifting statue mime artists? My bike frame can't be held by a Lidl stand, so I hang it from the ceiling using a suspension trainer:
matthewslack
2,412
1,606
DIY-wise, if I needed to do this, I would make a temporary crossbar, perhaps from two 2x1 battens with recesses to suit the frame members and a few bolts or screws to clamp them together and some protective padding.
AndyBike
1,665
705
The dutch(who apparently know a thing or two about bikes) use a sling and pulley system hung from above.
Reactions: danfoto
portals
775
228
As the man says, use the seat stay, this will give you decent balance too if you have a heavy rear hub.
17,206
I clamp the saddle post to the Park Tool PCS10 stand's arm.
6,712
if i worked for you id go on the sick with a bad back!! :p
get it off the tax man as a business expense ;)
8,746
lidls bike stands are now £39.99.
slowcoach
174
115
That is what I do. But to help me lift the bike into place, I put the front wheel on an upturned box, then I do not need to take the entire weight of the bike to position it in the clamp. Even I can manage that.
Reactions: Woosh and guerney
