What's my wheel diameter?
EmSeeDee
69
27
Coventry, UK
I know it seems a silly question, but looking around 'tinterweb it's not that easy.
Really the question is "what wheel diameter should I program into the controller of my new GSM kit"?
The manual for the 800S LCD says that I can choose between 16/18/20/22/24/26/700C/28/29, although the beast itself offers 27 instead of 700C.
On the other hand if I look up the tyre size (40-622) on the Schwalbe website it says that my wheel diameter is 2220mm, which equates to a diameter of 27.82 inches - so the nearest would be 28, and indeed Schwalbe classify it as a 28 inch tyre.
So - is the 800S set up to use nominal or actual wheel diameter?
Mike
5,786
Choose 28"
RobF
4,732
2,312
700c, 28" and 29" are all the same size, so that's the setting to use.
It will give a fairly accurate speed reading, but the circumference of tyres varies a little depending on the sidewall and tread depth.
If you want greater accuracy you could get a trip computer which will enable you to set the circumference of the tyre in millimetres.
willywombat
71
13
"700c, 28" and 29" are all the same size"
only the same rim size ....and i believe it's the approx diameter including the tyre that the kit wants to know . A 622 rim with a racing tyre will have a different total diameter to that with a bigger touring tyre and again with a 29er MTB tyre ...hence the three different choices , the difference in circumference between a big 29er mtb tyre and a racing tyre will be more than a" little"
5,786
I repeat (sorry) :mad:
You wrote 40-622 so choose 28" in the LCD
