Hi folks
Well, got the bike and kit back from TETS in Oxford today and have their explanation for what went wrong.
They said that the problem was the motor, that its internal wiring had been damaged when the wheel had opened up the dropouts. So they have put a new motor into the wheel and that should be the end of the story.
However… I am afraid I have another pair of questions for my elders and betters on this forum.
The wheel is slightly out of true in the fork. I have tried slackening off the nuts and moving the wheel within the fork and retightening and it stays in the same position. Is this a problem or does something further need to be done? (I am not sure that the brake looks quite right, either.)
The other question is whether a torque washer is essential. You will see from the photos that within the dropouts are ordinary washers. Last time there was a special washer with a bent extrusion which fitted into the slot. I thought this was necessary to stop the wheel tending to rotate within the dropout. Is this true? Could there be a reason why they didn’t fit one?
TETS is now closed until Wednesday, so I cannot ask them until then.
Thanks again for your help.
Andy
Andy
