will i notice a differance on hills 26" v 700c
footpump
713
75
76
hi all happy new year.
I currently have 26" mtb ebike vita uno and am fitting a kit to my 700c wheeled bike
but I am wondering will I notice any difference on hills if trying to compare the 2 bikes
as the gearing is a bit different both use 32 f on mth 700 either 39f or 30f chainrings.
my ebike is the only one I have ever ridden some forum members have multiple bikes.
mtb 3 levels pas 700c has kt lcd3 which can be (adjusted) 5 levels of pas,
idealy I would like to set the kt to be between level 1-2 of mtb to increase range.
thank you
30,863
Technically the smaller the rear wheel, the better the mechanical advantage and the better the hill climbing in any particular gear ratio.
Between a 20" wheel and a 27" 700c wheel, that will be noticeable, but the small under 6% difference between your 26" and the 700c wheel has little effect.
Therefore you can discount that wheel size effect. So just go ahead and fit the kit and then trim to the result you want on the LCD. I can't really advise better than that since I don't know what the motor/controller performance difference will be between the Vito and the kit, or even what sort of kit it is.
8,802
The kit will probably have a big say in the issue but as Flecc say's depending on the components used also gearing will equally play its paet.My CD mtb's and my 700c Oxy Boardman are fairly well matched for power, however I find the oxy kit on my 700c has the edge as gear change and strain on the drive train is kinder. Todays ride included a non stop climb up to Ditchling Beacon ( using speed setting 1 & assist 4) without having to stand on the peddles the ride down was better though.
footpump
713
75
76
thanks kit is rear moter wheel 250w 36v from electricbikeconversions knebworth herts, don't know make of moter, controller model kt36zwrt-lcd 36v 7-15amp battery 13.6ah
lcd ktl-lcd 3 I think its on woosh bikes site theres a thread on pedelecs convertions info
not too bothered about speed range is more important too me,but did buy kit prior to the throttle issues in jan 2016
trex
7,703
2,671
On assist level 5, the kit should be about 10% faster than your Vita Uno but that depends also on the tyres of the converted bike. Test the bike and let us know the result.
8,802
The kit is more then likely Chinese climbing ability with this kit may well depend on whether the hub is geared or not.
8,802
That very much looks like a SWXH !!!
footpump
713
75
76
thanks all yes that is the very kit I have 700 rear wheel 250w 36v (wish I could get the hang of posting a link etc) moter looks similar size to my fun 8 on vita uno
its figuring where to run all the wires ,not sure I want the controller in the (bag provided)
a bit off info they do a 27.5 moter wheel but its not on website, and at the end of the month will have some lights which run off the battery ,
5,786
You can buy an internal controller for that battery type at BMSBattery. If you don't mount the throttle you won't need the brake cut off so that means less wires.
footpump
713
75
76
thank you anotherkiwi I have looked on bms site I assume my battery is the 09 type case and they sell the mounting frame , I can see something called 36v so6s sine wave integrated controller at 50usd.
is this the correct item?
and does this controller fit to the mounting frame but have the 2 pin fitting to suite the battery.
at the monment would like to try full speed throttle,
5,786
argh! Can't see it any more! They keep changing things around.
No it isn't that one it is the one on the front page in the link to sine wave controller with a plastic shell
footpump
713
75
76
thanks m8 found the pic I can see comes in white or black with 3 leads out of it and same fitting to take battery, and fits on frame mount.
but is in a kit with lcd etc 87 usd doesent seem to be available on its own which is a pity as its nice and neat
5,786
I bought one yesterday. I need a 17 A controller and it was the tried and true option. I will tune it down from 20 A to 17 in the LCD.
I will have a go at waterproofing the LCD because it has started raining finally and I don't like being stuck at home.
I will have two throttles that I don't need and brake levers too but I will try and recover the switches from them.
Next step buy a battery with an 18 A BMS and more range!
