Wisper 705 SE battery meter?
eddieo
Banned
Jul 7, 2008
5,070
My wife has started commuting on her new 705 SE this week (14amp same as 905) it's the bike she did not want or need.... waste of money e bikes etc........ I am now not allowed to look at it, let alone use it! and I paid for itlol
She got upset when I came in on it the other week and she normally gets upset about nothing!:rolleyes:
anyway, her commute to Clapham is probably 8-10 miles return. She is normal weight, does not use the throttle much and when she gets back two battery lights are on and 3 out. that is, reading from bottom to top of 5 LEDs. the first is out, then 2&3 on and 4&5 out
not sure why first LED is out and that it appears the battery is half empty after such a short commute. Bike has probably only covered 100 miles.....
will charge it and check it in the morning before she leaves...
30,849
Has the battery been conditioned? The meter can rely on the battery being nearly emptied to establish a content zero point. If it hasn't been conditioned and nearly emptied after the first charge, the meter might think much more charge is the zero point.
eddieo
Banned
Jul 7, 2008
5,070
not really.........I ran it till nearly flat when we first got it, then we were away on holiday so never got the chance.
so we need to run it till empty, only then recharge and then see if its OK?
30,849
It's certainly worth a try Eddie, two conditionings is the norm for these setups.
eddieo
Banned
Jul 7, 2008
5,070
Just looked again (it has been charging for 3 hours) 4 lights on. the first still of. but when you turn the key of you get a red light on the first led which goes out after a while (have tried this twice)
this is looking like a battery problem do you think?
30,849
That is odd, certainly seems either a battery problem or a problem in the meter system.
eddieo
Banned
Jul 7, 2008
5,070
Have left a message with Norman at Wisper this morning:confused:
Thanks Flecc!
Hello,
From the three Wisper bikes I have here this seems correct.
The bottom (red) light only comes on when you disengage the battery with the key.
There are then 4 green lights that indicate battery charge.
I don't know if the red light comes on when the battery is completely discharged - but your battery sounds like it is working normally.
Cheers,
Martin
eddieo
Banned
Jul 7, 2008
5,070
Hello,
Cheers,
Martin
thanks Martin
Yes it seems so.........Dick from wisper contacted me explaining the situation, like you said the first LED is a red one and normally of until battery nearly empty. Odd that the manual does not explain this
30,849
Thanks Martin, that is an unusual arrangement, I don't know of it on any other e-bike.
Wisper Bikes
6,320
2,283
70
Sevenoaks Kent
Manual
thanks Martin
Hi Eddie and thanks Martin and Flecc,
Have you heard from Norman?
I will alter the Manual.
All the best David
eddieo
Banned
Jul 7, 2008
5,070
Yes thanks David had a chat with Norman:)
eddieo
Banned
Jul 7, 2008
5,070
Great Eddie, I look forward to seeing you soon (with the 906!).
All the best David
Be still my beating heart! (that's Shakespeare that is :))
eddieo
Banned
Jul 7, 2008
5,070
Didn't Richard the third once say
A Wisper xc! a Wisper xc! my kingdom for a Wisper xc!
Or was I dreaming? :confused:
Regards David
Err.......Probably to much ACID! in your youth:rolleyes:
