Wisper 905se
30,840
Frank has said the Wisper motor is the same one as the Quando and Torq, the Suzhou Bafang 8fun, but I'm not sure. None of the photos I've seen show it clearly enough to tell. It's in the back wheel in the Quando as well of course. It's certainly capable of the same performance as the Torq of course if that's the case.
frank9755
1,228
London
The motor on mine has a label on it saying Suzhou Bafang, model 129SWX36.
However, while its pretty quick, I don't know if it matches the performance of the Torq. People report getting 22-24 mph from Torqs. I've never got that from my Wisper; its more a 17-19 mph bike, on the flat in still air.
You would expect it to be a little slower than the Torq with the smaller 26 inch wheels but it feels like there is more of a difference than that would explain.
Having said that, I've mainly ridden mine in January, which was a windy month. I might get better performance in the spring, with better weather and a warmer battery.
Frank
30,840
Sounds the same Frank. In fact the Torq only reliably gets to 20 on the flat much of the time, and 22 when everything is favourable. They don't do 24 on a true flat stretch in still air, they need a touch of help to do that. Mine when on the over-volt 39.6 volt battery makes 24 mph when everything is favourable, but 22 on average. The speedo is calibrated accurately over distance, so no error from that.
C
Cyclezee
As the Torq is now only available in restricted mode, unless you do a DIY de restrction which would probably invalidate the warranty, the Wisper 905se must be the fastest production electric bike on the streets:D
John
30,840
I was thinking that myself John. The Forza was still in contention once the EAF control was dropped, but it's no longer a listed bike since eZee went all legal. I know that the new Torq motor had changes as well as the controller, so it may not be capable of the same speeds anyway, even if without restriction.
Of course it leaves Wisper very vulnerable if someone decides to be nasty about it.
coops
1,225
Manchester U.K.
My Torq1 motor has BF610B11884 etched on it, if thats any help?!
I get around 19-21mph full throttle without pedalling (36V NiMH) depending on charge level, a few mph more with pedalling but 24mph is a burst top speed only - not sustainable for me due to the legpower needed.
Is the 17-19mph for the Wisper 905se with or without pedalling Frank, or is that the range from motor only to pedal assist, or the 'charge level' speed variation?
If you mean that 19mph is the top pedal-assisted speed, that suggests the unloaded motor speed is not much higher & that the 905se motor is lower geared than the Torq1 8fun (all else being equal - battery etc. which it probably isn't! :)) even without the smaller 26" wheels which you point out - what is the 905se unloaded motor speed? That would be the easiest way to gauge the gearing I think. On my Torq its about 25-27mph depending on battery charge state, which with my 219mm circumference tyres amounts to ~317-342rpm for the motor.
John:
The Torq motor isn't restricted: it is geared for 15mph maximum speed in 28" wheels by the sound of it, so can't be delimited: the speed could be increased by increasing the battery voltage or regearing the motor. The F-series bikes are still as fast as Torq was previously as far as I know, so faster than the 905se?
Stuart.
frank9755
1,228
London
Almost...
What about the Ezee F-series bikes? I think they are now un-restricted. Faster still would be a Heinzmann Estelle Sport, and also a (high powered - I forget which letter it is) Flyer and the mythical Swizzbee!
frank9755
1,228
London
Stuart,
19 mph is with pedalling. I've done 24mph on the flat but I claim all the credit for that; the motor was putting its feet up!
I've rarely used the Wisper without pedalling (to protect the soft dropouts as well as preference) but I think it would do 15, maybe 15.5 mph. Your Torq sounds faster.
I'll try and measure the unloaded speed (need to fiddle as my computer is not on the motor wheel).
Frank
30,840
Almost...
Only the Forte of the F series is still available now, and it is firmly restricted, eZee's new legal only policy in place
The Flyer S and Swizzbee aren't e-bikes as we understand it, falling into a different class that we haven't got legislation for, so they are very illegal here. Only Switzerland and Germany in Europe have legislated for them, with requirements such as compulsory helmets and insurance.
I daresay the Heinzmann Estelle Sport is also in that same class, being German.
coops
1,225
Manchester U.K.
I wasn't aware of the Forza unavailability & Forte speed restriction, so looks like the 905se it is!
Frank:
I think they are similarly geared in that case, as flecc said. If you can get to 24mph (if its on the flat!) then the unloaded speed is most likely thereabouts or slightly higher, and the speed difference betwen 19mph and 20-22mph probably down to a combination of lower gearing in 26" wheels & colder temperature like you said :).
Stuart.
C
Cyclezee
Sounds like the end for de restricted/off road bikes from Ezee, I expect Wisper will follow suit except for the few that are still available from Germany.
By the way I wonder if anyone has ever been prosecuted for riding an illegal pedelec? Very much doubt it.
John
30,840
Yes, this is what Wai Won Ching said about the latest Torq Trekking and our preference for derestrictable bikes:
"In a conflict of interest between what customer or the market likes and what is legal. eZee takes the legal way, this is absolutely essential for long term consideration."
So that's emphatic, 15 mph from now on.
Never heard of a prosecution, and that's much less likely now, except for specials. I think the police are too busy going after under age kids on illegal mini-motos and quad bikes to bother with the very minor matter of an e-bike being a touch too fast.
Ian
1,333
Leicester LE4, UK.
I think the responsible manufacturers are striving for compliance with the forthcoming EU CEN standards relating to pedelecs. As the standards are supposed to ensure that only safe products can be sold, its a fair bet that to be certified as safe a product has to be at least legal.
coops
1,225
Manchester U.K.
And on the subject of the ezee motor in the EU Torq vs the kit being sold in Canada/US:
The controllers are the same for the US+Canadian vs EU market. The motors are wound differently for speed and watts...
... Battery life and amps drawn. As a simplified illustration the old model Torq would draw max. 16 amps at max. torque, the New Torq motor could draw over 20 amps and with a much higher torque delivered, that it operated right up to the maximum limit 20 amps imposed by the controller. The USA+Canada version for 350watts and 250 rpm would accelerate and do higher maximum speed operating at much higher Amps, but in fact lower max torque than the 250 watt because it reach 20 amps with more rpm.
Stuart.
frank9755
1,228
London
Stuart.
Stuart,
I've rigged up a spare computer on my motor wheel and, as I suspected, the Wisper unloaded top speed is lower, at 21.8 mph*. In my 207mm wheel I think that would equate to 292 rpm. I guess it is not surprising that the company may make differently geared wheels. I've not tested my Wisper on hills yet (as I live on the prairies of West London), but this suggests that it might fare better than a Torq on moderate hills, but it isn't quite as fast on the flat.
Frank
*I said I was claiming all the credit for getting it to 24mph! It was only a short burst...
coops
1,225
Manchester U.K.
:D Sorry I doubted you Frank! Its just it takes rather a lot of pedal power to reach 24mph, even without hub motor resistance! You sure you're not a professional cyclist? ;) :D
Thanks for measuring the rpm, its very interesting to know the comparison.
The rpm difference is not too great & with the additional lower gearing in 26" wheels as you say the Wisper905se motor will be more balanced between hills & speed, actual comparative performance depending on current limit/peak power output of 905se vs other bikes :).
Stuart.
268
My old Wisper 905e, with 10AH battery was amazingly fast. I fitted a digital speedo and got someone to follow me in a car with a digital speedo to check my bike one. It was accurate.
On the flat, with throttle only, I regularly achieved 16mph. Pedalling moderately, I always, without fail, did 19mph. Pedalling a bit harder, 22-23mph. If I pedalled hard and used the twistgrip throttle at the same time (twisted fully), 24mph was easily achievable and, on one notable occasion, pedalling hard and throttle on.... down a hill, I did 29mph. This felt pretty hair-raising though.
A great point I found about the Wisper was how very very quiet the motor was... just a tiny hum even when going fast.
coops
1,225
Manchester U.K.
Both your results & Frank's puzzle me rather - motor only 16mph max speed suggests motor power should tail off quite quickly with speed above that, yet if you can get to 20-24mph on 905e or se it suggests that motor assist is present at those speeds?
Could some extra motor power be phased in when you pedal I wonder, thus cicumventing the '15mph on motor only' rule?!!
When you say, Frank, that "the motor was putting its feet up", do you mean you weren't using the motor at all, or that you were throttling and it just felt like it wasn't assisting?!
Stuart.
frank9755
1,228
London
The Wisper is a pedelec so it may be giving more, but I doubt it. On other bikes which have both pedelec and throttle, and also a manual -such as Powacycle - the throttle gives you the maximum assistance while pedelec is always less or equal.
When I got to 24mph, my throttle was engaged but I believed I was over its upper limit. This was a one-off when I really pedalled hard, along the Embankment from Charing Cross to Blackfriars. I've never got those speeds on the flat on other occasions. But, Jimmy, I remembered your story about almost getting it to 30mph while going down a hill the other week. My speedo was on about 28.5 and I thought I'll give it another push, and got it to 31.1. Please let us know if your SE is any faster than your E. From that account, I suspect you might get exactly the same performance.
