The Wisper battery charger gets quite hot when in use, I've noticed. It gets hot top and bottom and makes a slight smell. My old 905e charger did this too. David Miall did mention to me something about having a fan-cooled charger for the bike at some point in the future, so presumably heat generation is undesirable.
In order to allow the dissipation of heat from my charger, I removed the small rubber feet, which exposes four crosshead screws. Undoing these enables the lid to come off easily. Inside the charger is a large aluminium heat sink. I then drilled holes in the top of the case... not particularly scientifically placed, I hasten to add. Heat from the heat sink can leave the charger by these holes and the charger definitely runs a lot cooler. I'm assuming that this will increase the life of the charger. I've attached a pic....
