B borisd0 Finding my (electric) wheels Jun 27, 2013 9 0 Sep 2, 2013 #1 Can I change the inner tubes on my Agattu i8 from Woods to Schrader valves? What are the pros and cons. With Schrader I can see the tyre pressure as I inflate the tube, can you do this with a Woods valve?
Zebb Esteemed Pedelecer Jun 13, 2012 371 12 Sep 2, 2013 #2 Can you not just buy a converter off ebay,should only be a quid.
flecc Member Oct 25, 2006 53,611 30,880 Sep 2, 2013 #3 Yes, you can swap straight over to Schrader, the valve hole is exactly the same size.
B borisd0 Finding my (electric) wheels Jun 27, 2013 9 0 Sep 2, 2013 #4 Zebb. I have a convertor and will change to tubes when these are worn out. It doesn't seem easy to see the tyre pressure with the Woods valves. I have a compressor and gauge and it very easy with Schrader vales to see the gauge & tyre pressure.
