Hi fellow ebikers,
I have a 2009 "Cyclamatic Power Plus" (24V Li-ion) which had been reliable up until yesterday when the throttle control spontaneously stopped responding. The pedal assist still works fine but twisting the throttle simply has no effect.
I disassembled the throttle-and-LED switch housing (Wuxing S29X-DX). The metal strip is in place, the hall sensor (S 49E 929) is connected, LEDs work as expected, as does the on-off switch. I also opened up the controller bay under the battery and made sure all the connections there were sound, which they seem to be.
Does anyone have any tips on troubleshooting this further? Is there a common cause for this, could a controller fault be responsible, etc? I'm considering buying a volt meter to check continuity and voltages but don't know what the values should be.
