Yamaha PW-ST Motor Jerky
E-bobby
how old is the motor new pcb and bearings be 500 quid
Not to sure to be honest, I’d imagine from new and I think it’s a 2022 model so prob 3/4 years old (could be 2021). There’s one motor on there, not pw st I think it’s like pw tx or smth for 250 130 miles on it. But I’ll have a mess with mine for now. See if anything’s out of the ordinary
E-bobby
The Bosch one only costs 25 Euro retail online here and the Yamaha one 28 Euro both plus 6 postage so 45 quid seems expensive but no idea how prices are over there.
Yeah little bit more over here, I just hope I can try and fix this motor could just be something rubbing or some dirt etc.
E-bobby
Hi all, just had a break from the haibike for a day and found that if I hold the power button and the down button (-) it goes into diagnostics mode, (Pc) can I buy a diagnostics tool and if so anyone got any recommendations for one that’s cheap and works, if it tells me error codes, if not then probably not worth it. Just so I get pointed in right direction. Thanks all
6,733
it wont work as it needs the link to the server like a dealer has and just give error codes anyway if a new sensor dont sort it try the display but have a look inside the motor as easy to do.
E-bobby
Ok thanks for that, yeah I did the sensor and didn’t sort I’m not sure how to test the display to see if the sensor signals getting there, is there a way to do that? Also I will probably start taking the motor apart through the week with the help of the video you sent. Thanks mate
6,733
the controller has uart programming so something could work but on these things u just replace parts.
my bike is 11 years old this year the only og part is the frame
E-bobby
Yeah, I don’t just want to go guessing and buy a display. I think the best bet is to probably take it to a bike shop nd see if they can see the error code. I’ll probably take the motor apart first as it sounds a little clunky sometimes.
Vodsel
9
Hi E-bobby
How did you get on with your Yamaha motor?
Mine is doing the same thing (flashing odometer, 0 for the speed etc).
Like you, I've had a lot more than 300 miles of use out of it before this happened.
Cheers
matthewslack
2,593
1,671
Hi E-bobby
Cheers
If you have checked it's not the speed sensor/magnet, then diagnostics at a dealer is almost certainly the next step. Bite the bullet!
Reactions: Vodsel
Vodsel
9
Yeah, I've tried a new speed sensor and it hasn't helped.
My Haibike Trekking 4 Crossbar 2022 with a "Yamaha PW-TE System, 250W, 60Nm, 25km/h" motor just went into this mode recently when I was doing an off-road hill climb I'd done many times previously with zero issues.
This is the bike:
I've seen about a dozen reports of this exact same issue on various forums. Many of them were fixed under warranty with a straight motor swap. Which suggests it's the motor that causes this particular issue. One that claimed the problem was that "the motor no longer detects the battery".
This specific issue doesn't seem like something related to the speed sensor as you don't even get a chance to have the system detect the sensor. As soon as you turn the bike on, the odometer just flashes, and the speed sits at zero.
I've seen a lot of reports of it happening when people have tried to bypass the speed restriction. It seems like it's software that kicks the bike into 'limp mode' if it detects you trying to do that, or in my case, via some kind of malfunction as I've done about 5000 miles on this Haibike and never messed with the restriction. The bike is totally vanilla.
It would seem a bit bizarre if this is an intentional disabling of the bike and there's no way to easily get it out of 'limp mode' via the control panel.
A lot of reports on this seem to have happened around the initial 300-mile mark, which means people could get the motor swapped out for one that doesn't have this issue under warranty. It seems a bit harsh to have it happen when the bike is out of warranty, so you have to cover some kind of software malfunction out of your own pocket.
I've seen no reports of anyone who's had this error having it again after the motor swap, so it seems like there possibly was a "bad batch" of Yamaha PW motors around 2002/2003.
Vodsel
9
As a follow-up...
I spoke to Haibike and they've said I have to take it to a "local" dealer for a diagnostic. This would make owning a Habike in most parts of the Scottish Highlands impossible without also owning a car. Probably other rural parts of the UK too. It seems to defeat the purpose of selling your car and relying on an ebike instead, which is what I did.
I'd have thought you could just remove the motor and send it to Haibike or possibly even Yamaha. Everyone has access to the postal service in the UK. Even on the remotest of islands.
I've added as much info about this experience as possible so that anyone else who's unlucky enough to have this happen can get all the info about how to handle it in one post/place.
matthewslack
2,593
1,671
Consumer rights extend beyond warranty: fit for purpose, known issue, expensive item etc.. Good luck!
E-bobby
Hi E-bobby
Cheers
So I’ve just phoned a specialist today and he said that it’s the pcb board that is in the motor. I had a look at mine and it looks perfect but he says one of the sensors has probably gone on it and it doesn’t show any signs of usage or burns etc. Hope this helps. Kind regards
Reactions: Vodsel
E-bobby
As a follow-up...
Yes my local dealer said you just bring the motor in to them and they actually don’t do it themselves they send it to someone, not sure who and they inspect the pcb board and tell you a quote, he said usually it’s 400-500. Personally I am going to wait for a motor to pop up on eBay as this one’s done 10000 miles and the bearings are probably about to be gone. I did see a pw te on eBay for 250 and it only had 160 miles. Regards
Vodsel
9
Thanks for the advice. I've had a look online and found the following:
you still have consumer rights under the Consumer Rights Act 2015 for up to six years from the purchase date (five years in Scotland) if an expensive item is faulty, as long as the fault was present at the time of sale and isn't due to your own fault or normal wear and tear.
Taking E-bobby's post above into consideration, I suppose we'd be looking at whether the PCB becoming faulty within circa three and a half years to be normal wear and tear. As there are no moving parts, I would probably say not as a consumer/layman.
Vodsel
9
Sounds like a good plan. My motor has probably done about 5000 miles or so. £250 for one that's done 160 miles seems like a bargain.
6,733
there the only place in the uk that service these motors all you have to do is remove it and they will send someone to pick it up and then give you a quote to fix itt or do it ur self and just buy the parts
E-bobby
Mine is about 4 years old and he still said that there is no symptoms that they are gonna go and you can’t expect it to go it just goes it must be at any random point. He said he’s dealt with a couple haibike a like that and that’s been the issue all the time. Hope you get yours fixed. Regards
Vodsel
9
Thanks for the further info. There's a good chance this issue is caused by an actual physical issue on the PCB. I suspect it could also be some kind of software limp mode that the motor is configured to go into if it reads the wrong speed. The reason I think that is because I've seen a load of reports of this exact issue from people who've tried to derestrict the motor by moving the magnet etc. If this is the case then replacing the PCB would fix the problem, as would replacing the whole motor, which seems to be the fix of choice for Haibike and the most common fix I've seen from Haibike dealers when still under warranty.
The most interesting post I've found is this one here:
It's the only post I've seen where replacing the speed sensor has fixed this exact issue. The extra step they took is to cycle the bike in limp mode for half an hour. I replaced my speed sensor the other day and only found this post today. I'm not long back in from a half an hour cycle on it in limp mode. No joy. Mine is still in limp mode...
I also found this video which explains exactly how to use the diagnostics menu on the Yamaha Sideswitch Display. So I've confirmed that my speed sensor is working and detecting revolutions of the magnet. I've also worked out that my bike has recently had an error 71, which "indicates a battery communication error, most often caused by a loose battery". I did have some issues like this the day before my bike went into this limp mode, though I never noticed the exact error at the time. Not sure if it's connected or not. Seems quite likely. I've had the occasional battery error issue in the past and just tightened up the appropriate bolts.
Hopefully some of that info is a help for you. I'll update you if I get any more.
