yosepower 36v350w no throttle or pas?
it is i footpump
102
23
76
hi all a couple of weeks go installed new 350w rear moter wheel to my kudos mtb, left all cables loose and thumb throttle worked, rear wheel rotated on my bike stand.
secured cabling etc (did not retest if i recall) today afix panniers go for a ride ZERO ASSISTANCE NO THROTTLE.
return home =chec=k connections, i cannot find anything obvious,tried another thumb throttle still the same.
when trying throttle no wattage shows on display the tempreture goes from 32c to a square type symbol.
not sure if pas sensor has anything to do with this malfunction all worked last year
8,788
Check brake cut out sensor's if fitted or disconnect them to see if PAS/throttle works again.
it is i footpump
102
23
76
Thanks Neil it turned out to be the moter lead from rear hub to wiring harness.
It was covered with shrink wrap tube, when fitted 2 weeks ago I made sure that both cables were connected correctly. And pushed fully home.
Putting bike into bike stand, or turning upside down today , must have pulled cables apart a little, Once I removed shrink wrap I could see the cable had pulled part way out of the socket , hence no pas,
8,788
