Where to buy BBS02 Controller
Finally got the new controller, took 2 days to get from Hong Kong to Birmingham then 7 (working) days to get it in my hand...boy what a struggle that was. Also I had a surprise VAT added by UK customs of £19. Connected and working fine I'm using the 42 t bling ring. The new unit goes to 40.3 MPH with no load, full PA and top gear. Same as before. I've got the prog cable and read the programming info but need to read it again and do it when I've got more time. Thanks all.
IP for Bikes?
Nice one Grey, good info!
IP for Bikes?
@ anotherkiwi I thought I'd get a quicker and possibly better answer here But I guess it would be good to ask manufactures direct. It would be a re-branding of the frame and forks on a small scale for commercial sale. I think if it was a Cannondale I would say so and be up front about it, because they're a trusted brand (right?) but then if I was to use an Ammoco for example I would only say if asked It is something that interests me...so many questions on this now
IP for Bikes?
Hey, So if I was to buy a bike, lets say a Cannondale. If I was then to get it acid dipped or blasted to remove all paint etc then get it re-sprayed, add a few self made decals and add an electric kit. Could it be sold without any kind of law suit that may come my way? Thx
It wasn't my intention to run it any faster than was good for the unit as I'm not so concerned about speed, 20-25 is all I need. Realising it could go that fast did spur me to get it that fast while riding though. So now I'm wondering if it could have damaged the motor (coil)? I'll fit the new controller and go from there with the prog cable.
Ok so ordered the prog cable, will need some help with that later. Contacted the seller who has replied asking for more info on the problem so waiting for a reply to that now. One thing I didn't mention, not sure if it's relevant but out of the box this unit was spinning the wheel at 40 mph without any load. I have reached 36 mph while riding. When I first setup the kit I was surprised that it was this fast but was happy that it was so didn't think to much about it. I did install a separate bike computer to compare speed and distance and they were almost the same so I know the readout was correct. I have since seen people mentioning hacking the BBS02 unit to get it to go 40 mph so is it possible that the controller I had working was setup in this way? As far as I'm aware the eBay seller just sells the units as they get them. Thanks
Thanks, i will get a prog cable for it. Didn't think about contacting vendor, to concerned with getting it back on the road asap. Will do so but it was bought on eBay so not sure about cover or if I have to send whole thing back but will check. All the connections were together and siliconed
Thanks for the help...ordered on a slightly express delivery and just shy of £90. I'll post back when I get it on.
Yeah I would seem that the controller is done. Tried what you suggested and no power at all...absolutely nothing only 3 months old. What is BMSB?
Nice one, putting things back together now so will try that next. Is there anyone in the uk where I could get one...kindda urgent
Thanks, tried disconnecting the sensor. I've got hydraulic brakes and atm just one sensor on the back...It's not very good in the sense that the space between the magnet and sensor is not easy to get right. I basically lock the back wheel in order for the magnet to be far enough away from the sensor to cutout the motor. I think this is why it is the controller. I was going up a steep hill and had to brake suddenly and that caused the motor to stop without being cutoff. There's no power when I throttle or pedal. I've checked the battery and that works, I've also tried my spare battery and nothing. Power to the LCD and display if normal. I've remove the motor from the bike, opened up the controller part to check the connections and the all look fine, no damage and they're all plugged in together. What else can I do?
Hi, Anyone know where I can get a new controller for my BBS02 36v 500w kit as I think I've fried mine Thanks
How to test power output from battery with multimeter
I best not lol the fewer things I do the fewer things I'll mess up Was sending it to woosh in a few weeks for them to check it anyhow, I think I'll send it sooner!
The USB used to be able to charge my phone but it doesn't now. When I plugged it into the charger, the chargers red light was on then went to green when fully charged (as normal).
No bang or smoke It's 02.3 with the battery off as well so it looks like no power
tezdread
Joined
Last visited
