rexy2
  1. rexy2 posted a topic in Classifieds
    I have a sensor near the crank so when you pedal t( i think its called a pedalec sensor)the motor kicks in, or is supposed to but dosent work. Its for a Moutain trailz bike and wondered if anyone no's where to get one Thanks
  2. rexy2 replied to rexy2's topic in Classifieds
    I live in Farnborough Hampshire
  3. rexy2 replied to rexy2's topic in Classifieds
    anyone??????????
  4. rexy2 replied to rexy2's topic in Classifieds
    Anybody no where to buy one cheap
  5. Power steering??????
  6. Hi ive got a Izip Mountain Trailz with the battery rack on the back. I did have a dodgy throttle but changed that and also changed the pedelec sensor on the crank. I brought this second hand and dont know if it worked in the first place. Ive checked to see if the sensor is close enough to pick up the magnets and it is 1mm away so should be ok, Just thought maybe i need to move if further away, will give this a try.
  7. So do you think the pedal sensor is up the creek
  8. I have a Izip bike, When I pull the throttle back in Tag mode the bike will power up to about 15 miles an hour without peddling. When I put the bike in pas mode and pull the throttle back the bike starts to excellerate before i start peddling, is this correct as i have a urburn mover and when i put this in pas mode the motor does not kick in until i start peddling.
  9. Wanted Izip battery charger for mountain trailz rackmounted type. I think mine has given up the ghost or i need a new battery pack, but want to try this first. Model QL-09002-B2401800F Input:AC 100-240v 50/60hz 1.5A Output:24v 1800ma This has the 3 pin connector to connect to the battery If anyone has got one laying around for free or cheap let me know. Im in the UK Thanks
  10. Wanted Izip mountain trailz rackmounted battery charger. I think mine has given up the ghost or i need a new battery pack, but want to try this first. Model QL-09002-B2401800F Input:AC 100-240v 50/60hz 1.5A Output:24v 1800ma This has the 3 pin connector to connect to the battery If anyone has got one laying around for free or cheap let me know. Im in the UK Thanks
  11. WOW Thanks everyone this is really helpful
  12. So can i buy a battery with a higher ah say 12ah and still beable to use the charger and it would be ok for the bike
  13. WOW thankyou i will get in touch with them now Thanks
  14. Thanks. I tried emailing these twice but no answer. I will try ringing. Thankyou
