Tyres
That's a good point maybe I will just go for 35 as my mudguards are fairly close fitting. I'll see how I get on fitting them the Kenda's go on and off with just my thumbs.
Tyres
Another question, can I fit a 700c x 40 instead of the 700c x 32 that is on the wheel and what is the difference ?
Tyres
Those pre slimed tubes sound like a good idea, every time I mend a puncture I just think next time I'll sort it but I just keep riding till I get another. I'll get her sorted over the Easter break.
Tyres
Wow, I would just like to thank everyone for their contributions, there's certainly some good ideas. It's much the same as awol all the puntures in the rear, a new tyre some slim and less chocolate bars maybe
Tyres
I must admit I have had a similar experience with slim type products but I think some Shwalbe's are on the cards.
Tyres
Thanks Gubbins, I'll take a look
Tyres
Morning all I'm using my Cannondale Quick 5 with an Oxydrive rear wheel conversion for short commuting and 4 punctures in 10 days on the stock Kenda tyres is enough, any recommendations for something more resistant ?.I don't do any off road riding just the lovely bumpy roads of Norfolk, the tyre size is 700C x 32. Thanks Gaz
Conversion for daily 20 mile commute
I also use my levers as clutches for want of a better description, you don't always want a shove at junctions or in busy traffic.
Hi Neil Yes I have the Panasonic 14ah battery it seems to perform really well. The charger did come with a non U.K. power lead but one from a laptop charger fits just fine. The other advantage it does have is a split pas ring which is easier to fit than removing a pedal, it was easy to install the kit but as with kits there's a bit of fiddling to do but I enjoy that side of things. We did a pre fitting of all the parts and it fired up first time no problem, we then tidied it all up. I'm fussy so all in all about 3 hours.
I did look at both kits but I needed a 700c wheel and I wanted the higher torque SWX02 motor so I choose the Oxydrive but it seems you can spec the wheel and motor from the good people at Woosh. When I bought the Oxy kit it was on offer and at £540 it's a great deal but I wouldn't have paid £799. Performance wise it's very good and I ride along with a cheesy grin (Easier to grin when you're not breathing out of your ass riding home lol)
Hi Neil I have recently fitted the Oxydrive kit and yes it can be massaged easily for that little extra, as for reliability I have only had it 3 weeks but so far so good. Ref Chris's question I emailed Andrew at Oxy and he said a torque arm was not needed so I have not fitted one and again no problems so far.
Hi d8veh I'm a lofty bloke at 6ft 4 and the Cannondale is a jumbo frame and just feels right plus I read on here that the Oxydrive kit is the same as on the Oxygen ebikes so it was a done deal.
Hi Neil Yes at £800 it's expensive for a rear hub but at £525 plus £15 shipping as it's on offer at the moment it's good value and easy to fit. That said I have only had he kit for two weeks but so far I am very happy with it. I should also say that it's my first foray into ebikes so I have nothing to compare it with but I don't want to be without it already
Hi Jake I recently fitted the same kit to my Cannondale Quick. I had the same problem fitting the LCD on fat bar centres and made a bracket out of a reflector holder, seems to do the job. The unrestricted throttle speed seems to be directly linked to the Pas setting, see the following. 1 8mph 2 10mph 3 12mph 4 14mph 5 18mph 6 20mph This is just based on raising the rear wheel.
Hi
No worries Chris if I can be of any help let me know and I look forward to comparing notes.
