Question/Advice needed from the techy gurus on this forum
Are the pinouts on Julet connectors all standardised?
Thanks very much for the in depth reply As long as motor cables are compatible I should be good as alll other cables are /came with Lishui/Yose controller, just awaiting the wheel and motor cable to start conversion/upgrade
I'm not sure I understand (new to this) How does reducing the controller to 16A reduce the range of the battery
Yes, but I think I will have to wait and see what connections are on the wheel before I order a motor cable (9 pin Julet connector on the controller end) - unless motor wheels are all standard connectors?
If all you need are motor cable, Pas sensor & 4 the n 1 cable it might be cheaper to buy separately from Yose accessories page. But if you factor in wheel & motor then you are probably right that a kit would be more cost effective. Left with more parts again but at least you would have some spares I would be interested in stickers when I come put a 350w rear on my Raleigh Pioneer
Thanks. Didn't know that.
Same here, which is why I wanted just a motor wheel Doesn't say spec on Cyclotrocity site but I'll let you know if there is any paperwork with it On Yose site they list the 15A controller for front 250w wheel and 18A controller for a rear 350w wheel
Thanks. It will be going on an old Powabyke Eurobyke 6 which has a full steel frame and forks in place of the original 200w brushed motor on the front
Hi I have a question regarding Yose/Lishui controllers I already have a Lishui controller (and associated LCD, PAS etc), for rear 350w wheel I think, as it is MaxCurrent 18A Looking at putting a front motor wheel on from Cyclotricitywhich is 36v 250W https://cyclotricity.com/uk/shop-parts/front-36v-250w-motor-wheel.html Would this controller be OK for this wheel? Thanks in advance
WHere to get wheel only and motor?
Yes, from what I can find the cheapest kit (non-waterproof & standard connectors) from Yosepower seems to be a cheaper option I do have an old Powabyke that I could replace all electrics and just keep the front motor wheel (Eurobyke 200w brushless) and use the leftovers of the cheaper parts that way
Thanks, will have a look after work
Thanks, but I can't see any 36v 26" or 28" front wheels on there, except in a kit (which I already have everything except the wheel motor)
Hi All Looking to get just a front wheel and motor I already have: Yose/Lishui controller C500 Dashi display Pedal sensor Thumb throttle 4-in-1 cable Brake levers/sensors Battery(Hailong 36v on order from Yose Power) Anyone know where I can get just a front wheel and motor? (either 26" or 28" - not decided which bike it will go on yet) Thanks
Avocet Hopper Urban SE Folding Bike - no battery
No probs
steveh6883
Joined
Last visited
